Old 06-01-2016, 05:27 PM   #1
SteveMD
Membro
SteveMD's Avatar
Default E-Fan Issue
I'm working on a car with a non-functioning e-fan. Grabbed another off a '01 V70 and was surprised that it started to spin as soon as I connected it. The ignition was off. I disconnected it until I can find out if that is normal behavior, some kinda brief self test? Anyone know?
Old 06-01-2016, 07:36 PM   #2
tryingbe
Boosting along.
tryingbe's Avatar
Stuck fan relay?
85 GLH 367whp
00 Insight mpg > yours.
Old 06-01-2016, 07:42 PM   #3
Chrisco
WRC addict
Chrisco's Avatar
Not sure what year it started. But e fans will run on a warm engine sometimes on s60/v70s. It shouldn't stay on too long though.
MODS: Bilstein HDs, Lesjöfors springs, sways, poly bushings, 2.5" exhaust, header, short throw shifter, Recaros, MS
and a V70R
1981-1982 Euro style 242, with GLT trim, rules over all other 240's.
All other 240's quake in fear at the '81-'82 242GLT, they go weak at the knees & collapse due to an uncontrollable adulation that's near idolatry.
Chrisco is offline   Reply With Quote
Old 06-01-2016, 08:09 PM   #4
SteveMD
Membro
SteveMD's Avatar
Cold engine. These fans use a PWM signal from the ECU to activate the fan. Inputs to the fan control module on the fan shroud are positive, negative, and PWM.
