Old 09-17-2016, 12:11 AM   #1
PardoR
PardoR's Avatar
Default 240 1993 AT: loss of power into reverse
It has been a couple of months since I made a atf change. The old fluid was cherry in colour but a little bit dark. So I changed it to ensure the right atf on the tranny. (Dexron III H - xcel).
But yesterday the car refuse to accelerate on reverse. I had two passenger and me, I put reverse and the car stops. Re start again, all was fine, engaged reverse, apply pedal and it stops again... What it can be????
I checked atf trans level and it was low, even the dipstick was without signs of atf. Tomorrow I will top up. But I would like to read more possible causes of this issue. It happens from one day to another... It has no sense to me. If the tranny were bad, I could not drive the car however it runs and drive fine. Just I dont have power on reverse! I cant drive a steep street to park the volvo....
Any thoughts? Thanks in advance.
Gracias a todos desde chile
PardoR is offline   Reply With Quote
Old 09-17-2016, 01:18 PM   #2
84B23F
84B23F's Avatar
Originally Posted by PardoR View Post
I checked atf trans level,,,,,,even the dipstick was without signs of atf.
When cold on level surface, and engine not running, remove ATF dipstick, and then reinsert it back into its hole. Then, pull the dipstick out, and LOOK at it...where is the level?
Old 09-17-2016, 05:49 PM   #3
Kjets On a Plane
Kjets On a Plane's Avatar
^You are supposed to check the AW auto trans fluid level with the engine running on a level surface.
How PSI a stock can support?
Always Be Crushing!
Old 09-17-2016, 06:17 PM   #4
PardoR
PardoR's Avatar
^You are supposed to check AWs running on a level surface.
Sorry I dont understand :(
Old 09-17-2016, 07:23 PM   #5
Otto Mattik
board member
Otto Mattik's Avatar
The ATF dipstick has 2 ranges, one *cold(*running 10 min) and one warmed up/*hot(*running 30 min). Volvo owner's manual states: "it may be lower if cold and may read higher if hot"
Most prefer reading ATF fluid on a warmed up engine, that has been driven, in fact there are specifics about moving gear selector through each gear, etc. suggest driving car at least 30 minutes, then check at normal idle while car is running (in park)
Old 09-17-2016, 09:01 PM   #6
84B23F
84B23F's Avatar
Volvo's Method: pg. 83 Automatic transmission
I've been checking ATF with engine off, and engine cold for years. I check it after engine has been off for some eight hours, overnight.
I was asking OP to do a specific task, and report back the level on dipstick.
Cold engine, level ground, remove dipstick, clean, and then reinsert, and pull back out again, and then read it.
Old 09-17-2016, 09:13 PM   #7
84B23F
84B23F's Avatar
An unknown one too...here's how to do it on a GM 125C transmission (photo), and I've done it for years.
On AW70 transmission, there is a way to do it cold, with engine off...been doing it since 2008.
Old 09-17-2016, 09:28 PM   #8
84B23F
84B23F's Avatar
Do it this way once:
1. Let vehicle sit overnight on level surface
2. Open hood
3. Remove ATF dipstick, clean it, and reinsert
4. Remove ATF dipstick, take a photo of dipstick where top fluid level is showing, and post it here.
Note - Always check both sides
Then do it the Volvo way, as posted above.
Old 09-17-2016, 10:15 PM   #9
PardoR
PardoR's Avatar
2. Open hood
GOTCHA! I'll do this and will let you know
Gracias amigo!😄
Old 09-18-2016, 12:04 AM   #10
Kjets On a Plane
I do "3" as a rough guess, but I check them hot running to be sure it's right.
Old 09-18-2016, 08:20 AM   #11
84B23F
84B23F's Avatar
I do "3" as a rough guess...
Cold method, as described above, lets a person know if they are good to go in the morning.
If your vehicle is parked on a hard surface like concrete, one can tell if transmission, rear-end, or engine oil is leaking.
But if parked on earth's ground, the cold method works best...since that's when your engine oil and power steering should be checked also.
Checking both sides of a dipstick is needed...the lowest level shown may be actual level.
AW70 dipstick may come up "dry" when first pulled in the morning; hence, clean it off, and reinsert, and then pull it out again, and then read it.
Old 09-18-2016, 09:07 AM   #12
Gussie
Gussie's Avatar
If your vehicle is parked on a hard surface like concrete, one can tell if transmission, rear-end, or engine oil is leaking...AW70 dipstick may come up "dry" when first pulled in the morning; hence, clean it off, and reinsert, and then pull it out again, and then read it.
After having done a bunch of cold, warm, and hot comparisons, I switched over to the cold method several years ago.
The dip stick almost always comes up dry first thing in the morning, and I've always wondered why/how that can be. Any idea?
Gussie is offline   Reply With Quote
Old 09-18-2016, 12:56 PM   #13
84B23F
84B23F's Avatar
Speculation - If ATF-dipstick's sealing o-ring is OK, once fluid has drained back to pan after driving around, there is trapped air in ATF-tube that exerts a downward air pressure on fluid in pan.
Experiment - Remove sealing o-ring on dipstick, and see what happens.
Old 09-18-2016, 01:44 PM   #14
coalminer
[QUOTE=PardoR;5469791
Gracias a todos desde chile[/QUOTE]
If it were me, I would remove the pan on the transmission and make sure that the oil filter screen is not blocked.
When this filter screen gets blocked, it starves the transmission of fluid flow and pressure.
A indicator of a blocked screen is as you describe. Transmission slips, cut engine off and sit for a few minutes, re-start engine and transmission acts normal until the cycle repeats.
When you stop the engine, it allows transmission fluid to back flow through the screen and partially un-block it. When you restart the engine, the clutch fibers, etc. that are blocking the fluid flow through the screen will gradually collect on the screen again.
Usually, you can drive the car for a couple of miles before the screen gets blocked again and the transmission begins to slip.
Doing this over and over can severely damage the transmission.
coalminer is offline   Reply With Quote
Old 09-18-2016, 03:29 PM   #15
PardoR
PardoR's Avatar
It was done when I changed the atf. the screen was cleaned...
I was reading about this issue on the web and also it can be the IAC valve or something related ( throttle body dirty, intake hose with holes, etc...) because a rattling idle can affect the normal drive when reverse is selected.
I will keep on this and I will keep you updated
Saludos y muchas gracias
Old 09-18-2016, 05:42 PM   #16
PardoR
PardoR's Avatar
What do you think about this?
[IMG][/IMG]
Old 09-18-2016, 09:29 PM   #17
84B23F
84B23F's Avatar
See page 27 of TP30578-1
So, where is cold dipstick level?
Old 09-19-2016, 01:59 AM   #18
PardoR
PardoR's Avatar
The link is corrupt or my iPad can't download it. Could you post a screenshot of it please?
Old 09-19-2016, 08:32 AM   #19
84B23F
84B23F's Avatar
Here's a jpg of it that might be downloaded on a home computer.
Old 09-19-2016, 08:44 AM   #20
Dadssleeper
Dadssleeper's Avatar
I have seen where the ebrake shoes will catch and bind in reverse , may want to jack it up and see if your wheels are free moving in reverse or if you turn the wheels backwards.
Old 09-19-2016, 11:29 AM   #21
coalminer
PardoR.....Are you saying that the rear wheels lock and won't turn when you try to go in reverse? Or that the transmission is slipping and won't pull the car in reverse? What exactly happens when you put the car in reverse and press the throttle?
Old 09-21-2016, 06:49 AM   #22
PardoR
PardoR's Avatar
The car moves into reverse when I put R only if the street has no steep and if I don't press the throttle, but if I press it, the car stalls.
The gearbox engages the Reverse but has no power when the throttle is depressed. Do I explain?
But I have something else to say.....
Old 09-21-2016, 06:58 AM   #23
PardoR
PardoR's Avatar
I checked the level when I post the thread and the atf even doesn't reach the dipstick.
So I topped up the atf with almost 120-150 ml of atf. when I checked again following the advices of 84B23F, the level was surpassing a little bit the MAX mark of the dipstick...
Maybe I pissed off the measurement but this confirms that the issue is not related to atf level.
Some illumination told me "do an obd diagnosis" and whr car throw the code 1-1-1 at the socket 2 and the 2-1-4 at the socket of ezk. It means "RPM sensor signal absent intermittently" but I have not checked nothing at all. Now I'm going crazy....
Old 09-21-2016, 02:32 PM   #24
84B23F
84B23F's Avatar
Cold fluid level is LOW. On my dipstick, there is a notch on dipstick, just above those measuring marks...add a little bit of ATF, then check it again the next morning. ATF level should be around that notched mark, when check cold.
Old 09-22-2016, 04:17 PM   #25
coalminer
So... the engine speed increase and the car doesn't move..... The transmission is slipping?
Or does the engine stall when you press the gas pedal?
