Old 05-20-2021, 07:35 AM   #1
TouringMusician
Default 1976 M46 OD issue.
1976 M46, OD always worked fine, no visible leaks.
Drove a friend 1.5 hours to the airport, all highway in OD, worked perfectly. Leave the airport, immediately starts slipping into and out of OD, but the OD dash light remains on.
Does the light remaining on mean that the issue is internal to the OD or is that light just wired to the switch on the shifter? It’s the old non relay switch setup.
Thanks!
1968 122s
TouringMusician is offline   Reply With Quote
Old 05-20-2021, 07:46 AM   #2
TouringMusician
Update:
Got 20 minutes of sweet blissful OD, now back to spastically popping in and out. Jiggled connections to solenoid, no improvement.
Driving home with civic level rpms in the slow lane :-|
Old 05-20-2021, 10:37 AM   #3
283SD
Check the oil level in the trans. With the light on it means the power is going to the solenoid. With low oil, it will hunt for pressure to engage the O/D
Old 05-20-2021, 12:58 PM   #4
VolvoScout
VolvoScout's Avatar
My guess would be one of the following:
1. The Overdrive may need to be resealed. (The three ports under the OD inspection cover)
2. The solenoid might need to be removed and cleaned.
3. The transmission and overdrive might be low on oil
Old 05-20-2021, 01:03 PM   #5
The Librarian
There's also the lockout switch.
Old 05-21-2021, 12:49 AM   #6
c1800
What he said, you might as well give it a full fill of new oil while you’re at it.
Old 05-21-2021, 10:34 AM   #7
dobber13
I had that problem once and it was the OD wiring had a break in one of the wires that would short in and out.
Charlie 85 244 TI B21FT 265K M46
dobber13 is offline   Reply With Quote
Old 05-21-2021, 03:28 PM   #8
240Redblock
^^ Had same issue, cleaned and crimped spade connectors and heat-shrinked and wrapped exposed sections, no issues now.
D.D. 1985 245 N/A M46
1982 242 N/A M46
1982 245 N/A M46
1973 p1800 es w/2.1T - project
240Redblock is offline   Reply With Quote
Old 05-23-2021, 02:25 PM   #9
TouringMusician
Ok, so it’s full of oil, I guess I just need to start tracing wires?
I just was confused about which side of the switch the solenoid and light were on to narrow down my search.
Been a while since I’ve had an m46, but were still using ATF type F in these guys, right?
Old 05-25-2021, 08:41 PM   #10
My car is fun hp club
Yes, Type F in there will work fine. Use a test light to check for power to the solenoid so you know the wires carry enough current. There is a short ground wire to ground the solenoid to the overdrive. Make sure that is clean and tight.
PS The shifter wiring can break from all the years of flexing.
Old 05-26-2021, 01:01 AM   #11
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Also, the solenoids themselves can go bad. Has happened a few times to me in the past.
@john242ti on IG
Old 05-26-2021, 08:33 PM   #12
2 old for this
With the key on engine off can you hear the solenoid click ? If no click start checking the wiring.
