Old 11-06-2020, 08:36 PM   #1
eebird
Default Touching up tiny paint chips
Like a lot of older cars, my 92 240 wagon has many tiny chips here and there around the body.
The paint has basically held up so well that I am not going to mess with doing a major overhaul until the paint is in much worse shape, but I was wondering about touching up some of these little spots.
There is rust on the metal, but the spots are super small. Should I leave them alone? Would touching them up trap moisture and make it worse? If I touch them up should I put something on the metal/rust first?
eebird is offline   Reply With Quote
Old 11-06-2020, 08:45 PM   #2
Elvolvito
Elvolvito's Avatar
I have the same exact issue on my 88 244 and Im wondering the exact same thing. I think Im just going to leave it alone till I can get the whole body paint corrected.
Elvolvito is offline   Reply With Quote
Old 11-06-2020, 09:57 PM   #3
nel621
You can try to remove the rust with a small fiberglass brush, then carefully spot treat and spot paint the chips. Takes a fine tip brush to do all of this.
Old 11-06-2020, 11:02 PM   #4
eebird
What would I spot treat the spots with before painting?
Old 11-07-2020, 02:04 PM   #5
Murploid1
Murploid1's Avatar
I ordered some base and clear coat from these guys a couple of days ago:
https://www.paintscratch.com/
My car was actually just painted a few weeks ago but I managed to get a couple of stone chips whilst on the freeway UGH!
I am simply going to clean the chips, use a fine brush to paint base and clear.
Murploid1 is offline   Reply With Quote
Old 11-07-2020, 07:52 PM   #6
nel621
Direct To Metal primer. You can buy a spray can, spray a small puddle on a piece of plastic and dip your fine tip brush in it.
Old 11-07-2020, 09:00 PM   #7
ovlov760
ovlov760's Avatar
Volvo dealers sell paint touch up kits for chips. They aren't that expensive.
Old 11-11-2020, 10:55 AM   #8
masaidwakeupson
masaidwakeupson's Avatar
I ordered a touch up kit from https://www.drcolorchip.com for my '91 940T and even the deepest pits and scratches are nearly invisible.
The results were much better than I had expected.
masaidwakeupson is offline   Reply With Quote
