Old 03-24-2020, 03:25 PM   #1
maxitoman007
maxitoman007's Avatar
Default Axle Shafts. Which will fit my 740?
I have an 87 740 turbo with a welded open diff. I'm wondering which donor Volvos will have compatible axle shafts so I can stock up. I have a feeling they are going to be the new weakest link on my car. I'm thinking any non-G80 740/940 would work? is that correct?
maxitoman007 is offline   Reply With Quote
Old 03-24-2020, 03:26 PM   #2
G80 would work as well.
Old 03-24-2020, 03:30 PM   #3
maxitoman007
I was under the impression G80 cars had shorter axle shafts. Guess not? so that means any 740/940? I know 240s had several different types over the years but 7/9s only stuck to one?
Old 03-24-2020, 03:34 PM   #4
On some early 240's (not sure about 740) you need to trim one axle shaft a trivial amount to fit a G80 in, but on later 240's and (again not sure of exact years) a G80 fits straight in. I put a G80 in my 93 240's rear axle without touching anything. They just made all the axle shafts a little shorter so installing G80 didn't involve a shaft swap as well.
Old 03-24-2020, 03:41 PM   #5
maxitoman007
On some early 240's (not sure about 740) you need to trim one axle shaft a trial amount to fit a G80 in, but on later 240's and (again not sure of exact years) a G80 fits straight in. I put a G80 in my 93 240's rear axle without touching anything. They just made all the axle shafts a little shorter so installing G80 didn't involve a shaft swap as well.
It makes sense then that all 7/9s would be similar as they came out later than 240s.
Old 03-24-2020, 03:53 PM   #6
sbabbs
sbabbs's Avatar
Yes the 740 940's with g80's have shorter axles. It isn't much. Probabbly work fine. I'll go look how much shorter and post back.
Old 03-24-2020, 04:38 PM   #7
maxitoman007
Sounds good thanks.
Old 03-25-2020, 04:04 PM   #8
dkrause
Max, I have a prepared G80 in my shop if you want it. Originally came from a 740.
dkrause is offline   Reply With Quote
Old 03-27-2020, 12:41 AM   #9
maxitoman007
Appreciate the offer however I’m just looking to get some axle shaft spares right now. Not a new diff but thanks.
