Old 04-21-2021, 08:51 PM   #1
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
Default Bulbs for 760/960 eCodes
I have the old Ecodes from my 960 - stored for the last 15 years - going to use them in my '91 745 - I don't recall what the 3 bulbs that are used with them. No markings on them to indicate
Anyone know offhand? H1? H4?
Old 04-22-2021, 04:05 AM   #2
Fa182
Stage 1
Fa182's Avatar
Old 04-22-2021, 06:38 AM   #3
lookforjoe
lookforjoe's Avatar
@Fa182 - many thanks!
Old 04-25-2021, 10:26 PM   #4
lookforjoe
lookforjoe's Avatar
Originally Posted by Fa182 View Post
pic
Question - do you have the pin schematic for the 4pole connector on your headlamps?
Old 04-26-2021, 07:10 AM   #5
Fa182
Stage 1
Fa182's Avatar
From my 97/98 Greenbook:
First picture is for low / high beams (pins 1,2) and second picture is for the fogs (pin 3)
Ground for both is pin 4.
Old 04-27-2021, 01:10 PM   #6
lookforjoe
lookforjoe's Avatar
Thank you, Sir!
Old 06-23-2021, 11:55 AM   #7
lookforjoe
lookforjoe's Avatar
I assumed the lower H3 (2) is the fog - however them seem to point at the sky (!) The DEPO lamps don't have very good adjusters. Is the lower inner in fact the foglamp?
Old 06-23-2021, 03:26 PM   #8
It's the high beam.
The circuit is really easy to figure out once you remove the rear caps.
Old 06-23-2021, 03:41 PM   #9
Fa182
Stage 1
Fa182's Avatar
It's the high beam.
That is wrong.
The lower inner H3 is the fog light.
The upper inner H3 is the high beam.
It's been a while, but as far as I can remember you can only adjust the fog lights horizontally, not vertically with adjuster knob.
So there must be something wrong with the insert, it's a separate piece from the big reflector that is held in via a clip or something. I don't remember exactly.
Part 27 on the diagram.
Old 06-24-2021, 07:30 AM   #10
lookforjoe
lookforjoe's Avatar
That is wrong.
Many thanks for the confirmation & schematic. I'll have to take it off & see what I can see with the innards. The Depot version has simplified adjusters (only two, no center one) - the inner does the height, the outers do nothing...
Old 06-30-2021, 01:00 PM   #11
lummert
lummert's Avatar
Thinking you may have to do a bit of work to fit 760/960 front light and grille parts to a 740. Maybe with mounting parts from a 940.
Old 07-01-2021, 08:37 AM   #12
lookforjoe
lookforjoe's Avatar
Its not bad at all on a 91 - just had to modify (cut & weld) the inner metal mount brackets for the revised offset, and trim the plastic filler cap
