Manbeard
OG 5EURO OG
- Apr 1, 2005
- fuquay-varina, nc
olov has had chevy truck shocks on his 244 for like 10 years...nothing new..
Sweetness. Was there a set that is a hair longer than these, or are these the longer of the two you were looking at?
What's it feel like ride wise? I seemed to feel every crack in the road when I had the Koni Yellows on, and to a lesser extent the same with the Burban GR-2s. These Koni Reds are better in that regard, but sometimes too soft...
Hahah well measure them up take some pics and maybe someone on here will buy them.**** hahahahaa, I think I have a pair of these from a 71 C10 project I had. Ordered drop shocks for it, never put em on the front, found the boxes when I was cleaning out the car. Too bad I'm at stock ride height....
What are those wheels off of? Also, does 3 cut coils give a ride height close to ipd springs?
I talked to a guy at the autocross this weekend that ran suburban shocks in his 240 in the early 90s. I wonder if they are similar to this.
These are even shorted than Suburban shocks.
^this is true. i just trashed mine acouple of weeks ago for some Billys for a Renualt, when i swapped rears..Doestch Tech! Also ran the BellTech "Nitro Drop" shocks, which IIRC were just relabed Doestch Tech "Nitro Slammer" shocks. Decent shocks, especially for the cheap price.
^this is true too. The Nitro Drop shocks i found has too soft a rebound....kinda like a... truck soaking up the bumps.wow, a shock that retails @ 30 dollars? I am pretty skeptical of the quality of the components and the quality control of a shock that retails so low.
Think I am going to order some of these this week and give them a shot, my shocks are all pretty blown on the 245
This is a great find - and i look forward to trying it out.
Thank you for the excellent reference. It would make for a great article.
Just a little side thing though - if you make an article out of it, please swap "Low" for "Lo" in the title
... unless the "Low" bit is a pun ... in which case it'd be rather amusing to see it written as: "Lo[w]"
I don't have the GR-2s any more. I ended up selling them to someone locally. Same price as these new, basically. I felt that the Konis and to a lesser extent, the GR-2s were slightly stiffer on compression than I wanted with the DD status my car normally fills.
Too soft on rebound for what springs? How heavy of a vehicle??
344266 from Baxters, is what I got.I want to try these burban gr-2s you speak of, Do you have a part number?
250lb, but thats not the problem.. remember folks who lower trucks arent looking for sports car type handling. They are still looking for a compliant full of Lux Rays ride. This is a trufe i've come to accept. its life taking a 90/10 drag shock and installing it on a volvo.... guess what...??...its gonna do the same thing it was designed to do- be a drag shock.
not truck, on my 242.
