Nice progress! Check the wiring diagram, but some (or maybe all) years of K-Jet have a wire from the coil "-" tab to the fuel pump relay (and to tach, if any). The fuel pump relay only turns on once cranking, and spark, is detected. It's a safety thing - don't pump fuel when the engine isn't running.
Will do man, I did change the coil so may have put something where it didn't belong! Thanks!
Time to wash out the cooling system. Nothing terrible, all clear water and a little sediment, no rust !
More than a bit of a process.
I have all new hoses and I'm cleaning up the t junctions.
Tested out the new thermostat
My overflow tank has a good bit of pitting on one side, may need to replace it?
Looks like someone used sealant where it meets the bracket too.
There was no thermostat in it !
Threw the cleaned up idle air control valve back in, fiddly thing to get the bolts in!
The front splitter clip had disintegrated see o quick but if cable tie action !
More on the rebuild of the coolant system later,all the hoses red rotten! Hope my heater core is okay !
