Old 07-26-2020, 06:50 PM   #51
IansPlatinum
IansPlatinum's Avatar
Very thorough & professional as always. Therapeutic, even. Hope it comes together and performs well come the 31st!
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
'93 Land Cruiser - "Ruby"
'01 Cherokee - "Janice"
Old 07-27-2020, 01:08 PM   #52
volvowagoon
volvowagoon's Avatar
Thanks. I really wish I was still sharing the same experience. To be honest, my enthusiasm for this car is dwindling fast. You'll see why in just a second!
Remember all that stuff about "thorough and professional"? I'm gonna throw that away for a second. This car needs to get me to work while I wait for those stupid rubber mounts.
A little cardboard...
Some zipties...
And there you have it!
I then went for a little test drive. It didn't go well. It ran as crappy as it always. When I got home and parked it in the driveway, I noticed that the main pump was growling just idling. I did the Fuse 4 and 6 trick. It made a normal noise for a second and then buzzed. Now what? Could I have electrically hooked it up backward? It did take forever to start the car which I thought was a bit weird for a return style fuel system.
I guess the next step will be to pull the supply hose off the main pump and try to pump fuel into a jug with the lift pump. Hopefully I didn't burn up either of the brand new pumps already.
At least I did this hack job NOW instead of waiting for the mounts to come on Thursday because then my mood would be even worse!
1986 Buick Grand National - Restoring to stock™
2010 C30 T5 - The boring but trusty daily - 192k
1989 245 DL - The boring but not trusty daily - 226k
IG: @v6buick
Old 07-27-2020, 01:22 PM   #53
volvowagoon
My hunch is confirmed. Nothing came out the supply hose, but fuel started pumping through the return hose, rail, and back through the filter and main pump. Yikes. I've never flowed backward through a regulator before either... I'm not gonna think about that yet. I guess my saving grace is that both pumps should have at least had cool fuel running through them.
Back to the tank I go! At least it will be nice and rust-free this time.
Old 07-27-2020, 01:26 PM   #54
IansPlatinum
Have you had someone jump the fuses while you are on the other end with a voltmeter on the unplugged supply pump harness? Takes 15 min to verify that the pump is getting proper voltage... I think they buzz & sputter when they receive too low voltage.
Old 07-27-2020, 01:33 PM   #55
oldschoolvolvo
oldschoolvolvo's Avatar
Yea give that a shot...I fought similar issues and turned out my (new) tank pump was underperforming. I ended up replacing it with the "upgrade" pump from ipd and the main pump has been quiet.
https://www.ipdusa.com/products/5799...ermarket-7845k
I used the value of ~1qt / 30 sec of operation for my evaluation (Greenbook TP30454). This was in a Kjet car so YMMV.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 07-27-2020, 01:38 PM   #56
volvowagoon
I can do that myself right? If I unplug, it shouldn't hurt anything having the fuses jumped. I'll give it a whirl
Old 07-27-2020, 01:42 PM   #57
volvowagoon
Okay... With the lift pump unplugged I can hear the main pump whining when I jump fuses. Now I'm confused.
Old 07-27-2020, 01:46 PM   #58
volvowagoon
The pump only seems to plug in one way which is guess is why I never thought twice about it. It also matches my the way I plugged in the old pump.
Old 07-27-2020, 01:51 PM   #59
IansPlatinum
That is strange... i'd reread art's guide again.
Maybe unplug the main pump too. put some long lead aligators on a volt meter, set to DC, and measure main pump voltage and then the tank pump voltage. You could have a tricky fuel pump relay? This is getting beyond my level of experience.
I'd just do that to completely cross out any chance of electrical issues. If you see a full 12.4-12.7 volts (also check your battery's resting terminal voltage), then you can probably cross off wiring. It'd be extra correct to do this test while the pump is actually plugged in though.
IDK about the main pump running with the fuses jumped though, I don't remember that happening when I did mine.
And you're certain you attached the ring terminals to the pump in the correct orientation too?
Old 07-27-2020, 02:09 PM   #60
volvowagoon
I'm going to read it now. The last post is edited with a picture.
Old 07-27-2020, 02:15 PM   #61
volvowagoon
Main pump thing is resolved. I'm a doofus and forgot to remove the in-tank pump fuse before doing the check. The main pump works as intended, but I cannot hear the in-tank pump working at all. I'll keep reading.
Old 07-27-2020, 02:34 PM   #62
volvowagoon
Looking at my pictures and comparing them to cleanflametrap.com, I have the revised sender with correct wiring which makes sense since that seems to have been corrected for five years. I checked voltage with the pump plugged in. I back probed the pump side connector to the black wire and put the other side on the brown ring terminal. Then I jumped the fuse. 11.9V. I don't know what to do at this point except pull the pump out again, leave it plugged in, and check voltage on the pump itself.
Old 07-27-2020, 04:04 PM   #63
IansPlatinum
removed
Old 07-27-2020, 04:04 PM   #64
volvowagoon
I had to put my brain in and start diagnosis. I checked the lug for power like I said, and saw that I was getting voltage to the sender, so I moved down the chain.
For sanity I jumped the pump to the power wire and made it spin. Sweet. Then I checked the resistance between the pump connector and the connector inside the car. This is what I thought I would see.
Then I moved up to the other side of the connector. It looks like I found my problem.
No good. Thanks aftermarket.
Let's rig it.
Then for sanity once again, I put it together, jumped the fuse again and watched gas pump out of the supply line. That should be the end of the saga, but it isn't. I went for a test drive. No dice. I came back to the house, jumped the fuse again, nothing.
Old 07-27-2020, 04:12 PM   #65
volvowagoon
removed
Haha I was about to reply. Mine is like it showed it your pic. I need to hang out inside and drink some water. I need to cool down not only physically, but mentally. I hate doing things twice, but three times? In this heat and humidity? I'm gonna lose it!
EDIT: ...and now a storm is coming through AGAIN probably just long enough to ensure that it stays absolutely miserable outside. When it stops I'll pull the supply line off again and jump the fuse. Something really goofy is going on.
Old 07-27-2020, 04:20 PM   #66
IansPlatinum
Whenever the pump is silent when jumping the fuses, that's when you need your voltmeter. Intermittent functionality could mean power loss or pump malfunction. The voltmeter will tell you which it is. Preferably, keep the pump plugged in, and find a way to safely get the voltmeter leads on the plug leads on that black connector in the trunk without shorting anything, and then jump the fuses and see what the voltmeter says.
You gotta do this while you are experiencing the 'no response' scenario from the pump though, so maybe wire up the voltmeter, go for a drive, then as soon as you come back you're ready to test it out.
Jump fuse, silent pump, voltmeter reads ~12V, you've got a problem between the connector & pump.
Jump fuse, silent pump, voltmeter reads 0 or a few volts, now you know you need to snoop up the line and check grounds, spades, etc.
Did you make sure to replace/attach the ground ring terminal?
Old 07-27-2020, 04:30 PM   #67
volvowagoon
Gotcha. Yeah, the ring terminal is secure. I'll try what you said. As expected, the storm is already dying down. Now I can start the sweating process all over. I wish we still had volvowiringdiagrams.com. I'll be completely lost if it's before the connector.
Old 07-27-2020, 07:56 PM   #68
volvowagoon
The rain stopped, so I went straight to the fuses. Everything worked fine. Figures. I then hooked alligator clips to the black wire side of the sender connector and the ring terminal. Those got hooked to positive and negative on my DVOM respectively.
The only thing to do then was go for a drive to see if it would change. I adjusted my rear view mirror and kept vigilant.
I never saw it dip below 12.8V after driving 50 miles in stop/go traffic, but it seemed to run pretty good the whole time... This time I stepped back and reflected. I haven't driven this car in almost two weeks. In the mean time, I've been driving a turbo Camaro every day.... Maybe a lot of what I've been feeling today is just placebo? After all, I used to make fun of people coming in to the Honda dealer after trading their Tahoe for a CRV and complaining about no power. I figured it was time to let Allie drive.
She thought the acceleration and torque was way better than she had ever remembered it, so I accepted the current condition as normal. This doesn't entirely explain the lack of audible lift pump action after the previous test drive, but I've been checking this entire time with the full interior together. Once I pulled the interior apart (after the post storm drive), shut the hatch, and tried again, I realized that it may have been impossible to know with all the lawn mowers and birds in the neighborhood. Then again, these last two drives were both AFTER the storm and therefore almost thirty degrees cooler than earlier in the day. That's a big swing, but I guess I'll keep driving it through the week and see if my condition comes back.
Thanks everybody for the help. I guess the moral of the story is to test your aftermarket senders before you put the whole car back together! Also, diagnosing "low power" issues on a car that's rated for less than a third of what your daily driver is making might be difficult.
Old 07-28-2020, 07:16 AM   #69
volvowagoon
Update: I drove it to work this morning and it still feels nice. Maybe I've just talked myself into thinking it's fine, but the cruise control is much more responsive, the engine accelerates and revs out much smoother, and the car takes off a lot quicker. I still have a buzzing noise, but I'm pretty confident that it's just a rattling heat shield or something. Either way, I'm writing off my post sender repair "issues" as placebo and unrealistic expectations. I'm going to stick some goo up by the seemingly broken muffler heat shield, install the the fuel pump mounts whenever they arrive, and send this thing to MI! Can't wait.
Old 07-28-2020, 10:04 AM   #70
IansPlatinum
I can see how going from 300 hp to a 240 would make you think something's wrong.
As my fiancee puts it, they're unsafely slow. She doesn't know about the kickdown cable though.
Keep your DVOM on hand & send it!
Old 07-29-2020, 06:50 AM   #71
volvowagoon
It got toasty yesterday, and I still haven't noticed any running problems. I have noticed that the new pumps are kind of noisy, but I only notice it when the blower motor is off and the windows are closed....
They must not be THAT noisy. Again, I think my brain is playing games.
I decided to buy Moose and I a little present for all the trouble. I think it's still going to be a while before the new trim shows up, but I have to figure out why it takes a minute for this thing to start working anyway. I'm guessing that the old gross power wire I used is junk. I'm sure I'll figure it out, but this was kinda just a novelty anyway. I've always thought the small tachs were neat and a perfect instrumentation addition for a car like this.
Old 08-10-2020, 02:47 PM   #72
volvowagoon
Sorry for neglecting turbobricks. I've been too lazy to get on Imgur.
Over a week ago, the fuel pump mounts arrived.
...and from there we we were off to Michigan!
THIS is more like it! I'll take 24 mpg while cruising 75 mph with the AC on and a full of luggage!
Back home
Without skipping a beat, the old Vo was a definitely a highlight of our week long trip! Would we have liked an extra 20 hp or so through the hilly high speed highways of northern MI? For sure. The car struggled a bit through there. For as much interstate driving as we do, the power boost we've been wanting is starting look like a bigger priority. I know for a while, I mentioned wanting to do an NA 16V conversion, but I've scrapped that idea. It's a ton of work and money for such little reward. Plus, I'd be screwed if the engine puked it's belt for some reason.
Mild +T on LH2.4? That's not out of the question! I like that I could do that whole conversion in a weekend if I have all the parts ready to go. I'd worry for the lives of the 200k+ mile skinny rods and AW70, but I can't imagine a 15g, with a good intercooler, trans cooler, oil cooler, and soft driving habits being THAT rough on things.
I'm just babbling though, I still have to focus on the things that don't work like the rear dome light, heated seats, a door switch, and more body work. It's fun to dream though.
Old 08-10-2020, 03:21 PM   #73
IansPlatinum
24-25 mpg is definitely sounding like everything is working properly. Especially cruising at 75mph.
great pictures, makes me want to hurry up and finish my renovations so I too can get back to enjoying 240 road trips
get a medium/thick sewing needle, pliers and lighter. hold the sewing needle with the pliers, heat up the needle with the lighter, and drag the hot needle into the apex of the dash crack, melting a small amount of the vinyl into a rounded shape. This will typically stop the crack from propagating further because it eliminates the stress riser.
Old 08-10-2020, 03:43 PM   #74
volvowagoon
Thanks for the tip! That sounds like something I'd only have patience for when the weather is much cooler though. I'm excited to see how yours turns out.
I mentioned the blurb about wanting more power, but I went for a drive soon after and had some thoughts. First of all, the OD solenoid is deleted. If I don't like the shifting in and out of OD, I should get that working again. Second of all, the cruise control started working like normal again! I actually set it on 80 with the AC on and the servo kicked the trans down and held the speed going up hills. It's NEVER been able to do that. I think I need to find another cruise control leak, because that may be the "boost" I'm looking for. The way cruise would loose speed before was like not having cruise at all.
Old 08-11-2020, 09:06 AM   #75
volvowagoon
I'm not really sure why I'm beating myself up over this tachometer. Although I failed to mention it, you may notice in the road trip pictures that the tach is out of sight and out of mind. I didn't have the trim piece so I'd rather look at the blank square anyway. However, this one does not even work right.
You can view the details here, --> https://forums.turbobricks.com/showthread.php?t=356201 but the gauge only seemed to work randomly. If I was smart, I would just return it to the nice seller who offered a full refund, but I like to punish myself and I'm going to be sad when my trim piece finally arrives with nothing to fill the gauge hole. There isn't a lot of information on tachometer repair, let alone the small tach, but the 30 year-old capacitors seem to be a go-to fix in these situations...
Hopefully I fixed it. I reflowed a couple sketchy looking connections as well, so I'm anxious to find out if this did the trick!
