dbarton
Dejected by Volvo Corp.
- Nov 17, 2002
- Prosper, TX
While doing some obsessive research into the flywheel profile for EZ-116K, I now have some questions about some inconsistent information.
Volvo factory flywheels and flexplates have HOLES (or recesses) rather than raised "teeth." It's my understanding that there are 58 recesses and one solid gap that represents the length of 2 recesses.
The second image has info from the EZK ignition greenbook for EZ-116K. It discusses raised teeth instead of recesses. Volvo refers to this as a "60/1 toothed profile," described as 58 short teeth and 1 long tooth. I know that counting teeth is different from counting recesses. The count will be 1 tooth off.
I compared this info to the "60-2" LH 2.4 flywheel from STS Machining. It has 57 short teeth tooth, however if you count recesses, there are 58, the same number of recesses as a factory flywheel.
So is the Greenbook image and info just plain inaccurate?
Thanks, Dave
Thanks, Dave
