Radtap
Well-known member
- Dec 16, 2020
- Tucson, AZ
I currently have a perfect log manifold that'll bolt up to my T3 no problem, I have 2 cracked 90+ manifolds that would either need an adapter plate or need to be milled to flat to accept the T3 as well as have the cracks welded. Motor in question is essentially a stock N/A block. My question is- will I see a significant enough performance increase to warrant paying to have the manifold worked and have it out a couple days or more. I'm a cheapskate and I'm impatient, I wanna put it together now. I've heard things about how some adapters cause fitment issues in 240s but I can't test fit right now to check clearance. Proper header is planned later down the road but right now its a mostly factory setup.
