Old 05-11-2021, 09:47 AM   #1
liamcafs
Default "Mr Fredrickson" A B8444S swapped 240 from the UK
This is my humble 87' 240 Mr Fredrickson. I've owned it for 3 years sometime daily driver sometimes not.
It all started with a plan to fit a B6254 and M90. The engine came "free" with the donor 960. Its not a bad choice as once in it provdes a good upgrade path for the 6 cylinder.
HOWEVER
With my 40th birthday fast approaching (mid-life crisis anyone ??) I decided I wanted to abandon all my previous efforst and fit the B8444s V8 from the XC90.
The excellent "Fake Race Car" build thread has been a really positive influence, also those guys have already been enormously helpful. The big difference is the aim I suppose. I want a unassuming standard sleeper street car.
These are some of the pictures I've taken so far. I'll post more in the coming days.
Pulling out the B2300E and Slushbox
Trying the B6254 and M90 together.
But no they don't fit together so have to split them and fit the gearbox from the underside
The standard B6xxx sump fits lovely with the front crossmember.
Set up for welding the mounts
This is the amount of trimming i had to do to the right hand side engine mount for steering rack clearance
liamcafs is offline   Reply With Quote
Old 05-11-2021, 10:16 AM   #2
liamcafs
Here is a picture of the new arrival in the workshop.
20210509_193358 by Liam McCaffrey, on Flickr
Old 05-11-2021, 10:48 AM   #3
Broke4speed
Broke4speed's Avatar
OOoh, nice. I'm very curious to see how this goes .
1984 244/ AQ140A / M46
Old 05-11-2021, 10:54 AM   #4
liamcafs
Measured up for some exhaust manifold flanges based on the gaskets.
My mate Carl drew it up in AutoCAD and printed some paper gasket templates. These turned out to fit perfectly!
Sent this off for waterjet cutting today. 10mm 304 im going for.
Old 05-11-2021, 11:56 AM   #5
liamcafs
Initial measurements show the FWD sump on the B8444s wants to sit right through the middle of the front crossmember. With that in mind I took the sump off to have a look at the possibility of modifying the sump. ie shortening the front and adding back the volume at the rear.
Its surely possible but I feel less inclined to chop the sump about after having a look in there. Could be quite complicated, I couldn't cut that much without interfering with the oil filter and I would have to move or delete the oil/water heate exchanger (I will probably do this anyway). Going to have a look at how much I can "shave" the front crossmember.
I also took the sump into work and shot it with the xref gun to see what grade it was. Star trek stuff that thing.
Old 05-11-2021, 12:10 PM   #6
liamcafs
Any advice on my crossmember clearance issue gratefully recieved.
Old 05-11-2021, 02:06 PM   #7
HiSPL
Fanking Champion 1993
HiSPL's Avatar
I'm more interested in what transmission you'll use and the engine management. Those won't be small hurdles to jump, but man I like your style!
Beets taste like buttfeet.
Originally Posted by Lando
Tinnitus and hearing loss? Sounds like your ears could tolerate some Bose 901s!
88 244
06 XC90 V8
03 V70
Old 05-11-2021, 02:47 PM   #8
liamcafs
Good points both of which I've been considering at length over the last couple of weeks.
ECU is easyish I have an Emerald k6 ecu which will run everything but only the vvt on the inlets(not the exhausts). Looking for advice on locking the cam phasors if anyone knows anything!
Gearbox is interesting, I've found out the engine shares the crank nose with a number of Ford engines so I'm sourcing an off the shelf flywheel to test fit. Failing that I'm going to machine a flywheel. I'm planning to use a bmw gs6-53dz/bz gearbox with some sort adapter plate or I'll modify the bellhousing if I have to.
Old 05-11-2021, 04:21 PM   #9
The nice thing about that GS6 box is that you can simply put a pilot bearing adapter pocket on the flywheel, which simplifies the installation somewhat as you would only need an adapter ring for the bellhousing instead of doing a cut n shut job.
Old 05-11-2021, 04:47 PM   #10
liamcafs
Took out one of the exhaust solenoids and fed it some dc to see how it behaved
http://https://youtu.be/wv1AV39Fuks
Old 05-11-2021, 04:48 PM   #11
liamcafs
That's a good point, they're pretty common and cheap over here too!
Old 05-13-2021, 06:19 AM   #12
antz
antz's Avatar
Looking good!!!!!!!!
antz is offline   Reply With Quote
Old 05-14-2021, 08:18 AM   #13
liamcafs
Made a start replicating the engine mounting flange last night, it only a template out of 3mm aluminium. Full adapter plate will be 12mm (1/2") steel i imagine.
Jigsaw, centre punch, transfer punches and step drill.
If you don't have any transfer punches, buy some they are really cheap and I'm amazed how often I reach for them.
Old 05-15-2021, 04:09 AM   #14
Råda
Volvoretard/Partshoarder
Råda's Avatar
Cool stuff going on here
Jonas
Old 05-15-2021, 05:54 AM   #15
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
I am stoked, looking forward for a bolt on swap kit :D
Old 05-15-2021, 09:53 AM   #16
liamcafs
Cheers guys, I'm having a great time working on this.
Went to the scrap yard this morning to look for a gs6 gearbox but they didn't have anything. Also I bought a used Ford mondeo flywheel on ebay to try. I'll be picking it up when I go to London next week.
Old 05-18-2021, 04:36 AM   #17
Sander
Good news everyone!
Sander's Avatar
Good stuff, what are you going to do for engine mounts?
Old 05-18-2021, 11:03 AM   #18
liamcafs
did a bit more work transfering the bolt flange to the template
Made a little shorty transfer punch and a transfer screw on the lathe
Template done
In the middle of making a centering jig this so I can find the crank centre line relative to the engine bolt flange dowels on or off the engine. Still some welding and trimming to do here but spot the "deliberate" mistake.
When I get the gearbox I'll do some thing similar to that flange. I've also ordered a chunk of steel to make an adapter to slide over the gearbox input shaft and bolt to the crank nose. I can then hold the gearbox accurately on the crank centre line when I mark out the gearbox bolt pattern.
Old 05-18-2021, 11:13 AM   #19
liamcafs
To be honest I don't know yet. When I get the gearbox and engine mated I'm going to dangle the assembly in the engine bay and see where everything sits. I have my old Homer mounts but I'm consigned to chopping the front crossmember about now.
Old 05-24-2021, 06:38 AM   #20
liamcafs
Welded up the centralising jig, this is really only to find the crank centre relative to the guide pins. Isn't strictly required but will help in marking/trimming the internal curve of the adapter plate. By the way "I am not a Welder". I get my welder friend to weld anything important.
Made a little boss to fit over the crank nose. This will be modified to fit over the gearbox input shaft and is for the purposes of keeping the input shaft concentric with the crank whilst I'm marking out the gearbox bolt pattern on the adapter plate.
Old 05-24-2021, 06:51 AM   #21
liamcafs
Some random information I've accumulated, stuff I found really difficult to find online without having an engine to measure.
The B8444s crank bolt pattern is 8 bolts on a 76mm PCD. However the spacing of one bolt is shifted by 4º so the spacing is 45º, 45º, 41º, 49º, 45º, 45º. The location dowel is a 6mm pin sitting 5mm proud of the mounting face. I haven't accurately measure this but its on an 80mm PCD approx.
The raised lip/cup on the crank nose looks to be 1.750". I measure it to be 1.752 and machined my boss to 1.753
Interestingly the engine bolting flange seems to be at least based on the Volvo Whiteblock. I tried the flange template on a spare T5 block. The locating dowels are in the same place relative to the crank centre and number of the bolt holes line up exactly.
My exhaust flanges should arrive this week, I'm collecting my flywheel and gearbox next weekend. I sourced my steel plate. The next months should see some good progress.
Old 05-24-2021, 10:29 AM   #22
Beachee
Beachee's Avatar
Default Volvo v8 - starter?
Hello
I am reading your thread. What about the starter? Any plans for that?
I remember back for a decade ago, an engine like this was fitted in a volvo 242 in sweden. I cant find the thread anymore, but I remember they had to chassis adjustment, because of the starter.
Beachee is offline   Reply With Quote
Old 05-24-2021, 01:19 PM   #23
liamcafs
Hi
I'm planning on mounting the original xc90 starter to my adapter plate and then cutting and bracing the gearbox bellhousing. You are correct depending, on where I place the starter I'm anticipating having to make some clearance in the tunnel.
Originally Posted by Beachee View Post
Hello
Old 06-10-2021, 04:07 AM   #24
liamcafs
Been a bit quiet last couple of weeks getting back into it now though.
Collected my GS6-53DZ and clutch kit
Built a little scaffold frame to hold and support the engine and allow me to roll it onto its end for working on the gearbox mounting flange easier. Worked really well. I can easily roll the engine on my own, I often have to improvise as I work on my own nearly all the time.
My exhasut manifold flanges have also arrived but theyre currently sandwiched behind the brackets in the frame picture.
I've also decided to machine my own flywheel. I've ordered some materials and hope to make a start sometime in the next week.
Old 06-10-2021, 07:18 AM   #25
740atl
FP4>HP5>TRIX
740atl's Avatar
that's pretty clever. I love it.
