530/405- turbo block cold start oil and coil
VolHi
anyone thinks thinks a joke. this is rebuilt to stage 1. and i'm gonna this on stand. i know someone has tried it. power coil, plugs, air, fuel, . how do the initial fuel w/o inj
As suggested you'll want to use a carb for the simplest way to run and engine on a stand. You will also need a distributor that has it's own mechanical advance built in.
so go old penta rebuilt carbs X intake, or use old volvo rebuilt carbs X intake. any adpaters and plumbing out there for all salesman for a holley,..etc
Way easier than that.
Get you a BBQ propane tank, and an adjustable regulator and hose off an old turkey fryer or something.
Leave injectors in the rail/mani to plug the vac leak.
Hook propane hose to an intake vacuum port.
Crank it up, slowly increase gas flow until it catches, adjust to idle speed.
Won't be able to rev much but should work great to idle test the engine.
