- Jun 26, 2002
- Apache Junction, AZ
So you said clutch slipping at the track? Times?
Good to see you got it all together
Good. Now bring it to Davis.
Im thinking about it, but that too much of a risk to drive that far. I will just post pics instead.
Stock LH2.4, bigger injectors, 3.0 bar FPR, no 02 sensor right now either.
Stock...
Do it. There's alot of us going.
I have to fix my oil pressure problem
Brand new B204FT exhaust manifold.
Too bad the oil pressure light came on today and wont go off.
I guess those $400 oil lines aren't doing much for you.
you have to make power to break em 'air manual transmissions. if its going to be making power, hope you at least did the accum mod, or you'll be back out there pulling another auto shortly.
Nope. You really need to just let that one go too, dude. Im not running those 204ft oil lines on this engine. The B204FT oil feed is for a banjo fitting and it actually seemed to line up just fine. The oil return pipe didnt really look like it was designed to fit the angle of the boss on the B234 block. I am gonna see what happens when I put a 16v head on a B230FT. I think the B204FT oil lines will work OK.
@ovlover: I am running a B204FT exhaust manifold. I have no idea what the clearance would be with an adaptor plate. I personally dont believe in those things at all. Its like forcing a oval peg down a square hole. However, I will tell you that the clearance between turbo compressor housing and B234F motor mount when using a B204ft exhaust manifold is VERY VERY close. Maybe a couple millimeters close. I had to grind down one of the bolt bosses to get the housing to clear and be clocked properly.
Im gonna test the oil pressure with a guage ASAP and post back with results. Its gotta be the oil pump, pressure spring, or pickup tube:
http://images5b.snapfish.com/232323232%7Ffp6325%3A%3Enu%3D5992%3E%3A64%3E25%3A%3EWSNRCG%3D3286765%3A5234%3Bnu0mr[/QUOTE]
i was just curius if there was enough clearence between the turbo and strut tower to run an 8v mani + adaptor. 204FTs are non existant in aus, and for that i highly doubt the possibility of ordering one, and i dont want to get a custom mani. This may seem obvious, but everything besides the mani, is all 230FT items yes? What you have is EXACTLY what i want with mine. It looks awsome!
