Old 08-02-2020, 08:35 PM   #26
2turbotoys
Salaminizer once again
2turbotoys's Avatar
Originally Posted by classicswede View Post
No gasket matching is grinding the ports out so they are the same size as the gaskets. All it does is slow the gas speeds. The throat is not where there is any restriction in the head but around the valve stem is where the work is needed
It doesn't matter at all under boost, which is the only way I like my redblocks. But ya the worst part is directly under the valves.
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 08-03-2020, 01:52 PM   #27
Wrong. It matters boosted or not. Either way you are working toward optimizing gas flow.
Old 08-03-2020, 06:12 PM   #28
grumpy dad
Hi
well this is a easy argument to sort
in standard form
940 turbo 163 horse power
940 16 valve 153 horse power
so its a no brainier
if you use the penta head you get even more because of the comp ratio
so put the same amount of boost in to the 16 valve and you get 229 horse power
I run a 2.5 penta 16 valve on carbs and am very happy with it in my Amazon
grumpy dad is offline   Reply With Quote
Old 08-03-2020, 06:38 PM   #29
Sure we know about the efficiency and total power possible. The op question is that the power you can make with a 8v would satisfy most people. At least that's what I thought he meant.
There is a level of mechanical complexity that you are adding and you can make fun power with a big valve 8v.
I like 16v too. Just happy with the power I've made with 8v for fun on the street. I have a 16v head stashed if I decide to make the leap. There was a really nice 245 with an n/a 16v at Carlisle last year that really caught my eye.
Old 08-04-2020, 12:46 PM   #30
DET17
Reformed SAABaholic
Wonder if that was the old Conner850 wagon..... he had a thread a few years back, but I believe he has vanished back into BMW land.....
DET17 is online now   Reply With Quote
Old 08-04-2020, 01:28 PM   #31
woodenpudden
lacks goats
woodenpudden's Avatar
Originally Posted by Tsayloco View Post
Certainly more than adequate for me, I also prefer the 8v sound. Call me a weirdo. IDK I'm not smart enough to argue the details. 16v does have its own inexplicable cool factor.
Pictures are great, here's a relevant one: a cutaway of the 530 head's exhaust port.
Originally Posted by DMFWallace View Post
Flunt delivers!
woodenpudden is offline   Reply With Quote
Old 08-04-2020, 06:54 PM   #32
hessam69
What are we looking at here?
Old 08-04-2020, 06:57 PM   #33
Old 08-04-2020, 08:14 PM   #34
2turbotoys
2turbotoys's Avatar
My car was faster with a heavily ported head, as well as my brothers. I did them myself. I guess others results may differ.
Old 08-04-2020, 08:26 PM   #35
Kjets On a Plane
Kjets On a Plane's Avatar
You cut your LS in half and think it's better?
Ok & impressive feat, that...
How PSI a stock can support?
Always Be Crushing!
Old 08-04-2020, 08:51 PM   #36
2turbotoys
2turbotoys's Avatar
Haha, I have more than 1 car, I would be more likely to attempt a W16 LS. And fail miserably
Old 08-04-2020, 11:30 PM   #37
Marvelous3
Who engineered this?
Marvelous3's Avatar
Yes. For 99% of tbers that want 300 horsepowers!!!1!0” an 8 valve head is plenty. Some bigger valves and an enem cam, which all bolts on using stock hardware, is more than enough.
Old 08-04-2020, 11:32 PM   #38
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
whatchu need bigger valves for? 300 is easy on a stock head with an ipd cam. can't be a sissy with the mbc tho.
Megasquirt Tuning!
Old 08-05-2020, 12:13 AM   #39
Marvelous3
Marvelous3's Avatar
So on the average “tuned” set up someone can run lower boost to make their 300 safer.
Old 08-05-2020, 08:36 AM   #40
Stiggy Pop
Stiggy Pop's Avatar
I'm still working out the details for my feature on True Life: I spent $4,000 on an 8v head
'79 242
943 pickup
Old 08-05-2020, 10:28 AM   #41
linuxman51
linuxman51's Avatar
what's considered lower boost? we're devolving into semantics, but I'd say 20-24psi isn't really "high" boost, but it's not necessarily "low" either.
Old 08-05-2020, 11:13 AM   #42
Marvelous3
Marvelous3's Avatar
Anything under a bar I’d consider “low”.
Old 08-05-2020, 11:43 AM   #43
linuxman51
linuxman51's Avatar
I think you'd struggle to hit that mark below a bar unless you had something special
Old 08-05-2020, 12:02 PM   #44
J_Jones
J_Jones's Avatar
https://www.onallcylinders.com/2016/...ocket-porting/
J_Jones is offline   Reply With Quote
Old 08-05-2020, 12:31 PM   #45
There's no real use in gasket matching a 8v when you're using the stock intake manifold. If you do the math for port wall taper based on the valve size, the ~40mm intake port entrance is about right... the issue is the factory taper is very severe (over a short distance) and the rest of the intake port is undersized. Once you remove ~3-4mm from the middle of the intake port , you get into the correct approximate CSA and taper.
Enlarging the exhaust side too much will cause sever issues with reversion along the port floor as well. It is better to widen the exhaust port than to remove material from the roof and floor. This is what Erland suggests, and what I've seen from heads where I ported the exhaust too much. The port walls will be really clean, but have a pocket of carbon on the floor of the port.
Pocket porting and blending in the SSR is where these heads need the most amount of work.
Old 08-08-2020, 03:40 PM   #46
It was a gray late model wagon. I think he said 91. M47 with a n/a 16v. Used a lot of Volvo plastic and made it look like a stock installation.
Old Yesterday, 02:47 PM   #47
240240
Poobacca wil survive 2020
240240's Avatar
A stock b230 skinny rod NA aw70 is better than a 16valve head for 99% of tbricks.
Change my mind.
Originally Posted by bobxyz View Post
I'm sure glad that our mods are protecting us from excess poop in these trying times of TP shortages....
Shoot the poop!
I commute daily hoping to get that sweet insurance settlement on my 244.
240240 is online now   Reply With Quote
Old Yesterday, 03:18 PM   #48
TurboDutch
Change my mind.
if it aint blown.... it sucks!
bigtime!
TurboDutch is offline   Reply With Quote
