Hello,
Recently i bought a full set of early type engine 740 engine mounts that use rubber inserts rather than oil filled. Now after doing some measurements i've found Land rover engine mounts are almost exactly the same dimensionally. Which is handy as poly inserts can be had for quite cheap over here in UK.
The landrover mounts, have a slightly larger(5mm) OD than the volvo rubber inserts, so i will make up a washer to go either side of the mount to spread load a little. The landrover mount is also 4mm taller and with 2x2mm washers either side the engine will be raised around 8mm maximum of 10mm.
These are the poly inserts
Will this cause any problems? Only thing i can think of is the gearbox may end up being at an angle slightly which could cause some misalignment with the driveshaft.
Any info would be great.
Thanks,
Lee
Thanks,
Lee
