Old 02-22-2022, 05:54 PM   #1
VolvoLatAm
Default which mount is needed for the Power Steering Reservoir
for 6819752
https://www.volvowholesalepartsdirec...4/6819752.html
What is the part number for the reservoir to chassis mount?
Old 02-22-2022, 06:06 PM   #2
- Stock PSI Or Bust -
No love for the 91+ integral pump?
how psi stock cna sprout?
Old 02-24-2022, 03:36 AM   #3
Kjets On a Plane
Kjets On a Plane's Avatar
Pay $ for *new* Volvo parts to install that remote reservoir junk everyone in the USA hates/throws out if they can/don't have to run it (I think you have to run remote setup/something like it with 16V k@@l-@id &/or NIW super-tweak intake?)
Or are you a poor SOD w/a case of the crabs (carbs) in South America & can't use the '91+ integrated reservoir pump (pump itself is the same as most chevy trucks w/vol-void pressure valve/setting & vol-void spec/offset/diameter etc. V-belt pulley) w/its stamped steel brackets w/garden variety '85+ alloy block bracket for some reason?
Some rare-bear '85-'90 cars where the dealer replaced/updated the hoses & flushed the system on time/preventatively the pump isn't all starved/moaning & aren't a mess of oozing worn out rotten hoses, but most are?
Other than rust-proofing the battery tray or pressure hose that sometimes gets chafed/busted if the driver engine mount is busted, can't say I see much/any advantage to that wretched setup they ran '85-'90 on the USA cars & throw it out if it needs anything more than 1 updated hose (that I have from S-canning that setup) or a top-off or oddball '85-'90 pump that somehow runs dead silent.
How PSI a stock can support?
Always Be Crushing!
Old 02-26-2022, 12:49 PM   #4
1987 Volvo 240
Old 02-26-2022, 02:33 PM   #5
The Librarian
The bracket for a 240 is part number 1359805.
https://www.volvowholesalepartsdirec...8/1359805.html
Old 02-26-2022, 02:50 PM   #6
white855T
He's wants to run 7/9 style. Alternator on the driver side, ps pump on passenger side.
Old 02-26-2022, 03:20 PM   #7
The Librarian
I know but there's only one bracket to mount the reservoir for a 240. If he wants to mount the reservoir closer to the pump he could probably put the bracket on the passenger side strut tower.
Old 02-26-2022, 05:00 PM   #8
Radtap
Radtap's Avatar
Angle iron, drill, welder, 1-2 hours and you can mount it wherever and however you want
Feedback
Radtap is offline   Reply With Quote
Old 02-26-2022, 08:43 PM   #9
VolvoLatAm
I found the mount down here in Latin America on a junker car. I think I am going to mount it on the right passenger side to keep all fluids on one side.
Old 02-26-2022, 08:45 PM   #10
VolvoLatAm
I have found almost all pieces with the help of white855t and you, now I am just trying to find the lower ac compressor mounting hardware for 3514231 mount. I don't understand how to get the exploded diagram view from volvopartswebstore off of just the mounting part number?
Old 02-26-2022, 10:00 PM   #11
The Librarian
This?
Old 02-27-2022, 02:09 PM   #12
VolvoLatAm
This?
Yeah that's it. Thanks for the help. Got the parts
