Old 03-21-2021, 03:47 PM   #1
VolvoScout
VolvoScout's Avatar
Default AW70 Shifter Linkage Broken
The shifter linkage on my Grandmother's '93 AW70 240 broke free from the transmission.
Anyone know where I can source the front (bulbous) part of the linkage?
[IMG][/IMG]
Old 03-21-2021, 04:07 PM   #2
The Librarian
The adjusting sleeve is NLA from Volvo. Used parts frequently have a broken plastic wave washer which allows some slop in the swivel connection and eventually will cause it to fail as your grandma's did.
https://forums.turbobricks.com/showthread.php?t=330394
Old 03-21-2021, 04:20 PM   #3
MasterBlaster
MasterBlaster's Avatar
[IMG][/IMG]
Part number 381825, and nobody seems to have it any more.
Try the "wanted" section here.
Others have had the same problem...
http://forums.turbobricks.com/showth...ghlight=381825
The straight part is supposed to turn in the bent part to allow for length adjustment of the totally rusty threaded sleeve. You could try "re-peening" it (as mentioned in the above post) after getting a washer or two so it can still spin, or if you're happy where it is/was and will NEVER want to adjust the shift lever ever, ever again, you could just push it back into the hole and weld it solid. (I never said that, so don't blame me for any subsequent length errors).
1990 740GL
520,000 km so far...
Old 03-21-2021, 05:32 PM   #4
planetman
planetman's Avatar
I have a new 1.
Eric
Torrance, CA 90502
Old 03-21-2021, 05:55 PM   #5
VolvoScout
VolvoScout's Avatar
Originally Posted by planetman View Post
I have a new 1.
PM'd
Old 03-21-2021, 06:33 PM   #6
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Grab Eric's assembly, then get the rest of the shift linkage parts from a west coast car. That way, you can get rid of the rest of the rusty mess.
@john242ti on IG
