Old 10-09-2018, 08:48 PM   #1
lummert
lummert's Avatar
Default Bosch 0 280 155 811 Injectors
Stumbled upon a fuel rail including injectors from a scrapped Buick 3.8 Supercharged V6 engine at my friends junkyard. Specs show they are from 02-05 Buick Park Avenue Ultra with Supercharged 3.8 V6.
36.25 lb/hr @ 3 bar
381 cc/min @ 3 bar
274 grams/min @ 3 bar
42 lb/hr @ 4 bar
High Impedance
GM # 24508208
White body
EV1 connector
4 hole
Planned use: My 88 765 with B230FT. Currently running Bosch 0 280 150 934 from earlier supercharged Buick 3.8 V6.
0 280 155 811 shows Gen III EV1 Jetronic port /4 hole nozzle.
Motor Man Fuel Injection Supply shows Bosch 0 280 155 811 flow rate being:
34.3 lb/hr
360.5 cc/min
260.8 grams
43.5 psi
3.0 Bar
Old 10-10-2018, 12:46 PM   #2
lummert
lummert's Avatar
What? No one has any comments on Bosch Gen III injectors with Jetronic EV1 connector and 4 hole fuel nozzle?
Old 10-10-2018, 01:02 PM   #3
oldschoolvolvo
oldschoolvolvo's Avatar
Looks like they are slightly bigger than the 0-280-155-830 / 0-280-155-766 T5 injectors.
Should be fine if you are looking for some more boost & fuel.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 10-10-2018, 01:59 PM   #4
lummert
lummert's Avatar
Ford Racing Red 30# Bosch 0 280 155 759
Factory injector for 5 cyl Volvo Turbo engines
Flows 30.75 lbs/hr @ 39 psi.
I'm going to try running the 0 280 155 811 at 2.5 bar (39.15 psi)
These should flow 31.30 lbs/hr at 2.5 bar (39.15 psi). I have 2 BMW 2.5 bar fuel pressure regulators that are direct fit to the fuel rail.
Old 10-10-2018, 02:04 PM   #5
Beep beep zip tang
Are you still on lh2.2? You might have to fiddle with the amm screw to get a not too rich idle.
Old 10-10-2018, 04:32 PM   #6
lummert
lummert's Avatar
Yes, it's still LH2.2 and yes I'm able to use my LED tool to fiddle with the AMM POT screw.
Old 10-11-2018, 08:34 AM   #7
tryingbe
Boosting along.
tryingbe's Avatar
Other than injector flow and impedance, there are also injector dead time and voltage correction to set.
85 GLH 367whp
00 Insight mpg > yours.
Old 10-11-2018, 02:58 PM   #8
lummert
lummert's Avatar
Injector dead time as in adjusting the AMM?
Voltage correction as in bypassing the ballast resistor?
Old 10-12-2018, 01:13 PM   #9
tryingbe
Boosting along.
tryingbe's Avatar
No to both.
Injector dead time is the time that the injector needed to go from fully close to fully open. Dead time spec is usually at 13.8 volt and it is important to idle quality.
Voltage correct is measured in ms/v because the injector will open faster if you apply more voltage, and slower if you apply less voltage. Since car's voltage can vary a pretty wide range between 11.5 to 14.7, the ECU is programmed with voltage correction in mind.
Old 10-12-2018, 01:40 PM   #10
Beep beep zip tang
No to both.
Don't worry about it Lummert, it's not adjustable on 2.2 unless you burn a new chip. Just get the mixture right and see how it drives. I had to lean that screw all the way out to run brown tops.
Old 10-12-2018, 05:32 PM   #11
lummert
lummert's Avatar
I found that these Gen III injectors are an upgrade to 0 280 150 934/0 280 150 945. 0 280 150 934 are what I'm running now. 0 280 150 945 are Ford Racing red top 4-hole nozzle injectors.
0 280 150 934
315 cc/min @ 3 Bar
30 lbs/hr @ 43.5 psi
Found mention of Volvo 94545560, 0 280 155 759, and Ford Motorsports BB302 replacing old style Bosch 0 280 150 945, 0 280 150 911.
Old 10-13-2018, 07:39 PM   #12
lummert
lummert's Avatar
I installed these 0 280 155 811 injectors today. They required placing a spacer on the bottom then the o-ring as the measurement between the top and bottom o-rings was less than with the stock injectors. Got everything back together and started up after the fuel got to the injectors. AMM pot screw adjustment with LED tool ended up at 004 ohms. Decided too much fuel and installed BMW 2.5 Bar fuel pressure regulator. Adjusted AMM pot screw, need a test drive to determine if the engine will have enough fuel with the 2.5 bar FPR.
Old 10-14-2018, 11:25 AM   #13
lummert
lummert's Avatar
Using fuel flow calculator to calculate fuel flow rate of 0 280 155 811 injectors at 2.5 Bar.
Old pressure 43.5 psi (3.0 bar)
New pressure 36.25 psi (2.5 bar)
Size of injector 34 lbs/hr (354 cc/min)
Injector flow rate at 36.25 psi (2.5 bar)
31.038 lbs/hr
326.21 cc/min
Old 10-14-2018, 01:06 PM   #14
lummert
lummert's Avatar
My car is running like a scalded ass ape with these injectors @ 2.5 Bar. Even the idle is better.
Old 10-14-2018, 01:19 PM   #15
thismachine13
Curious what your setup is.....turbo size etc?
thismachine13 is offline   Reply With Quote
Old 10-14-2018, 01:42 PM   #16
lummert
lummert's Avatar
1988 765 with B230FT. stock exhaust manifold and TD05-12b. 2.5 Bar FPR is Bosch 0 280 160 226 from BMW 318i.
Old 10-14-2018, 01:47 PM   #17
lummert
lummert's Avatar
Found mention of the white-body newer style injectors, the slim ones, from either an S60 T5 or a Supercharged Buick V6 saying these are an alternative to the browntops. Post#118
http://forums.turbobricks.com/showth...t=20676&page=5
Old 10-15-2018, 01:26 PM   #18
lummert
lummert's Avatar
I found this info in reference to boosted LS fuel injectors. This may explain why higher flow injectors work better on lower pressure.
The best performance for an injector is to maintain a constant DELTA pressure across the injector (which is why there's a vacuum/boost input into most regulators).
Basically, you want a rise of one psi of fuel pressure to each psi of boost (which is what the 1:1 should do if it can handle boost). This maintains a constant pressure across the injector (which makes the tuning much easier, otherwise you have to compensate for pressure in the tune too).
If the injector can flow sufficient flow at a lower delta pressure (and not kill the spray pattern or cause lazy closing of the injector...some rely on the pressure as part of the closing force for the coil).
The lowest pressure that will flow the amount needed through the injectors will prolong the life of the pump and put less heat into the fuel. The current (heat) in DC motors is directly proportional to the mechanical load (pressure).
Running a boost/vacuum referenced regulator reduces the pump load even more.
Old 10-17-2018, 09:36 PM   #19
lummert
lummert's Avatar
I've found mention of a Bosch Gen III injector that runs at 2.5 bar.
0 280 155 010 fits 92-95 Porsche 968
32.5 lbs/hr @ 36.25 psi
341.6 cc/min @ 2.5 bar
Also found Bosch Cobalt Blue at rated at 2.7 bar and at 3.0 bar
0 280 155 767 replacement for Porsche 968
363 cc/min @ 2.7 bar
Latency 12 volt, 0.605 ms; 14 volt, 0.305 ms
14.0 ohms
4-hole disc nozzle
Bosch Cobalt Blue 0 280 155 767
375 cc/min @ 3.0 bar
12.0 ohms
4-hole disc nozzle
Resistance difference of 2 ohms between 2.7 bar and 3.0 bar.
Old 10-23-2018, 04:06 PM   #20
lummert
lummert's Avatar
Update:
Tried the 0 280 155 811 injectors with the 3 bar FPR again. Unable to properly adjust the AMM with these injectors @ 3 bar. swapped back to the 2.5 bar FPR.
Noticed something else...I no longer have a hot start issue that seemed like the spark plugs were fouled with fuel. I'm also noticing less fuel smell and less smoke from the exhaust. After looking up leaking fuel injector symptoms I have determined that one or more of the Bosch 0 280 150 945 white-top injectors were leaking down into the intake manifold.
I pulled these injectors and installed thinner lower spacer. I then installed the lower o-ring and original pintle cap (more of a ring). These injectors are about 0.05 inch shorter between the o-rings than the originals.
Old 10-25-2018, 04:47 PM   #21
lummert
lummert's Avatar
I'm trying to devise a test to check the Bosch 0 280 150 943 injector that I took out for leaks. I know I should have tested the injectors for leak down before pulling them from the B230 fuel rail. From what I've read I can pressurize the injector inlet with air and check for air bubbles from the injector outlet into a container containing something liquid such as rubbing alcohol.
If I find that I have four good 0 280 150 934 injectors out of the six that I have I may put them back in. These injectors are a better match for a B230FT running LH 2.2
Old 10-26-2018, 08:45 PM   #22
lummert
lummert's Avatar
I pressure tested the four Bosch 0 280 150 934 injectors that I was previously running at 20 psi. Two of the four leaked down within 5 minutes.
Old 10-27-2018, 08:02 PM   #23
lummert
lummert's Avatar
Tested the 2 spare 0 280 150 934 injectors. They passed, so I now have 4 good injectors out of 6.
Now the big question...Do I keep running the GEN III 0 280 155 811 White-top injectors flowing 346.89 cc/min @ 2.5 Bar (380.0 cc/min @ 3 Bar) or do I swap back to the 0 280 150 934 white-top injectors flowing 315 cc/min @ 3 Bar (300.1 cc/min @2.5 Bar)? The LH 2.2 AMM has to be adjusted quite low for the higher flow 0 280 155 811 injectors, even at 2.5 Bar. The 0 280 150 934 injectors work just fine on LH 2.2 at 3 Bar.
Minimum pressure for Bosch GEN III injectors is 30 psi (2.0689 Bar), Maximum is 100 psi 6.8964 Bar.
Old 10-30-2018, 03:12 PM   #24
lummert
lummert's Avatar
Still looking for comments on reinstalling the 0 280 150 934 - 30 lbs/hr @ 43.5 psi (315 cc/min @ 3 Bar) injectors. These injectors came from a Supercharged Buick 3.8L V6. They are high-resistance 4-hole nozzle injectors with the correct grooves for fuel rail clips. Ballast resistor has already been bypassed.
The 0 280 155 811 - 34.3 lbs/hr @ 43.5 psi (360.5 cc/min @ 3 Bar) injectors came from a Supercharged Buick 3800 V6, The flow rate of these injectors @ 3 Bar appears to be too high for LH 2.2 with stock AMM. Running these injectors @ 2.5 Bar appears to be the only option. I do not have a 2.7 Bar fuel pressure regulator available to try with these injectors. Mpg's seem to be much lower than with the 30 lbs/hr injectors @ 3 Bar, so I'm guessing that these injectors are not atomizing the fuel all that well at 2.5 Bar.
Old 10-31-2018, 12:39 PM   #25
lummert
lummert's Avatar
Managed to find washer and pintle cap kits at Advance Auto. $1.29 plus tax for 8 kits. Next is a O-ring kit. About $4.49 for 12 o-rings.
My car is being really thirsty with the White Giant injectors. 65 miles on $10 worth of gas. 3.691 gallons at $2.709 per gallon. This was 40 miles highway and 25 miles in town. Averaging 17.6 MPG. My car can average 20 MPG.
