Old 05-21-2020, 12:22 PM   #1
90volvo
Default Time to freeze 240?
On my 90 240 my compressor is weak and my evap. has a hole. Im probably gonna install Classic Air. Dave Barton has a great write up on it. But I have a question? Does the whole dash have to come out? Im going to attempt to install Classic Airs big unit. Will keep you all posted. Thanks for any help.
Old 05-21-2020, 01:30 PM   #2
apachechef
Burnt Sierra Madre
dash is easy part, cleanflametrap.com guide
like others have said, find a 1993 240 and save headache
Dammit, Lummert.
Old 05-21-2020, 01:40 PM   #3
90volvo
Finding a 91-93 240 is far and few. Then by the time I buy new heater c. And evap. And fan. I’d be getting close to a classic or vintage air.
Old 05-21-2020, 02:15 PM   #4
apachechef
Burnt Sierra Madre
Originally Posted by 90volvo View Post
Finding a 91-93 240 is far and few. Then by the time I buy new heater c. And evap. And fan. Id be getting close to a classic or vintage air.
wow, what does the vintage air cost?
Old 05-21-2020, 03:19 PM   #5
90volvo
400-550? MAybe cheaper depending on which size you choose. Im gonna go as big as possible. Classic Air is little more expensive but might be better. has everything you need to replace the components under the dash. Will take some custom work but can be done. Heres a good write up on it. Even when my ac worked with upgraded condensor and good comp. IT would struggle if temps were above 90. Keep in mind my evaporator needs replaced . I dont want to do all that work without upgrading it. Heres an exellent write up on it.
https://www.240turbo.com/classicair.html
Old 05-21-2020, 05:27 PM   #6
dbarton
Dejected by Volvo
dbarton's Avatar
If you can figure out which one flows more air or has more power or bigger motor, start with that. So that could mean a larger unit than I did. I think Vintage has units with 2.25 or 2.5 inch duct exits. Mine are only 2 inch. I'm not unhappy with my flow, but I'd be happier with more.
Dave
'84 242ti, owned since 2003. Always garaged since brand new. Old-school rounds because. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with 0.73 OD, 3.91 diff with unmodified G80.
Volvo Seeks Divorce from Volvo Enthusiast Community: www.prancingmoose.com/#novolvo
Dave's Volvo Page: www.davebarton.com
Alternator Idler Pulley Project: https://forums.turbobricks.com/showthread.php?t=350085
Old 05-21-2020, 06:27 PM   #7
90volvo
Hey dave I was hoping I would hear from you and get your input. I emialed both places, havent heard anything yet. Im about to go out and start taking my dash apart. Thanks
