i already checked nothing blocks the cooling system timing is at 10? most likely the gauge is wrong my buddy has a gauge so i can check but only he should be here on friday so hope is still there
generally if timing is too advanced the car will idle poorly but won't overheat. if on the other hand, it's retarded, it will tend to run hot (And may or may not actually overheat)
1. i finally found out the issue it ran so lean that it overheats i tried to adjust the amm but the led is off all the time only if the engine is off it was on and i already turned the screw to make it richer a bunch
2. idle rpm isnt adjustable , the iac valve plugged in versus out nothing happens and turning the idle screw nothing happens
3. stalls when letting off gas from any boost
4.afr gauge died a day before my old engine blew up so i dont know how lean it is
