vegiguy
- Sep 6, 2008
- Newton, Kansas
I have had a major oil leak on my b23 for the longest time and finally got around to changing the seals and gasket on the front of the engine. Is it best to press the new seals on the lower cover while it is off of the engine or do it after it is back on so as not to risk damaging the seals sliding them over the crank and auxiliary shafts, or does it matter which way it is done? I think it would be easier to get the seals pressed in the cover nice and straight when the cover is off of the engine.
I noticed this engine is missing the flame trap and pcv hoses on the oil separator so there is no positive pressure that I can see to help the combustion gases escape the engine: Could this be contributing to my massive oil leak problem? I've read the post about it being an option to just let the crankcase vent to the atmosphere, but it seems like it would work better if there was some vacuum there to help pull the gases out and thus help prevent the build-up of pressure in the crankcase.
Another concern I have is whether the tube going down into the engine is plugged up (or even there at all). Is it possible to stick a wire down in the hole to make sure this is clear? Which of the two holes is the tube supposed to be located in (front or back)?
Thanks for any help.
