rb92673
racecar
- Jan 17, 2017
- San Clemente
I installed Microsquirt on an unknown mileage B230FT with T3/T4 50 trim turbo. I had a local shop dyno tune it. Peak 187 TQ / 200 RWHP @ ~12 PSI. Since then I used auto-tune and megalog viewer to dial in the fueling. Overall we were happy with the performance for Lemons racing. At our last 24 hour race, we went through 5 gallons of oil, so we pulled the engine to keep as a backup.
Meanwhile, I rebuilt a B230FT squirter block. Sleeved cylinders 1 & 4 and bored all to +1 piston size. Added new +1 stock pistons, china rods, oil pump and bearings. Transferred recently rebuilt head from old engine and put on new engine. I have no idea if compression changed. I did pull the VX cam and replaced with an IPD turbo cam. No other changes.
After connecting everything, engine fired right up. I let idle for a bit, then turned it off.
My question is will the Ignition and AFR tables transfer over to the new engine, or do I need to have someone smarter than me rebuild those? I am assuming I will just autotune the fuel tables at the track. I cannot street tune, my options are dyno or racetrack only.
