Old 11-26-2016, 03:44 PM   #1
brickcupra
Default 240 / 7mgte swap
Hi guys, I here doing this again after my wife disconnected the computer and erased all the info I had typed. I am new to the bricks. I am a a Toyota fan, but I always wanted a Volvo wagon since I saw one back in the 80's. Finally I got one in a great deal with the exterior( red) color I wanted and the black upholstery I wanted. I got it back in September and I've been working on it on spare time after work. I have already pulled the engine and trans out of it. I had to put the cressy to sleep due to the fact it rusted beyond my budget and parts are practically impossible to get. One day after work I glanced at a 240 and the LED lit, Why not a 7mgte -240 combo? the engine only has 9k, yes 9,000 only since I rebuilt it.
Also I am changing the lug pattern for 5-114 to fit some 17 inch Maxima wheels.
I was blessed to find a supra in the local junk yard. The cressy hump is a front one and does not fit. The supra is mid hump and easier to make it work in the 240 chassis.
Old 11-27-2016, 12:32 AM   #2
Steve Zissou
Steve Zissou's Avatar
Do it. Post lots of pics. I'm a closeted Toyota fan and straight sixes are my favorite swaps in the 240. Plenty of rear sump 1JZ's floating around for cheap also.
I don't think I've ever personally seen an M engine swap, but plenty of threads on JZ series.
Steve Zissou is offline   Reply With Quote
Old 11-27-2016, 01:15 AM   #3
BillyMaysHere
BillyMaysHere's Avatar
get to reading:
Old info and discussion about the swap
http://forums.turbobricks.com/archiv.../t-108633.html
diff detween 2j and 7m
http://www.driftworks.com/forum/tech...s-2jz-gte.html
2j swapped 240 volvo (with detailed pics and info)
http://www.turbobricks.org/forums/sh...ighlight=supra
sweet 2jz swap in a 740, but great build and all around info
You having the hubs redrilled? or getting adaptors?
I am actually the gentlest and kindest of souls, you know that...I wish peace and happiness to everybody
Was a sandals-and-socks elbow-patch-cardigan-wearing bearded college-professor 10mph-under-the-limit-in-the-fast-lane typical Volvo buyer from 1993 really caring about some sort of limited edition numbering?
BillyMaysHere is offline   Reply With Quote
Old 11-27-2016, 02:33 AM   #4
brickcupra
Default 7mgte 240
[QUOTE=BillyMaysHere;5510473]get to reading:
Hi bill.im redrilling them myself.I used the rotor of a 2002 infinity and the center hole fits iperfect to make the pattern .Im using Chevy trailblazer studs complements of the local junk yard. I got one done already.
Old 11-27-2016, 11:05 PM   #5
brickcupra
Question 240 7mgte,
How do I post my pictures here?
any tips would be greatly appreciated
DZ
Old 02-13-2017, 10:00 AM   #6
MoCounselor
MoCounselor's Avatar
[QUOTE=brickcupra;5510497]
Originally Posted by BillyMaysHere View Post
get to reading:
What model of Infiniti did the rotor come off of? I've been pondering a switch to 5x114.3 for my 242, so this would be good info to know.
MoCounselor is offline   Reply With Quote
Old 02-13-2017, 10:53 PM   #7
brickcupra
infinity I 35 2002 front wheel drive. The rotor fits perfect in the hub and I used smaller drill bits to guide the big one. Once done I hammered the new studs complements of the local junk yard from trailbrazer. I gotta finish the rest of them as I am finishing the motor and tranny mounts. Good luck
https://postimg.org/image/8fonfv0af/
https://postimg.org/image/o82sk4oin/
the first pix is the volvo hub drilled using a nissan rim as a guide to keep the studs in place. I used the lug nuts to pull them with a air gun to place.
the second pix is the rim in place. Just barely missed the strut, it cleared about 1/2 inch.
Old 02-19-2017, 12:41 AM   #8
brickcupra
Here are more pictures .
https://postimg.org/image/id7fk30zp/
https://postimg.org/image/dqalxf53z/
https://postimg.org/image/a8o0rmnod/
https://postimg.org/image/5tpylcam3/
https://postimg.org/image/3k8e9yt6x/
https://postimg.org/image/fdq8n02wr/
https://postimg.org/image/5805xc96d/
Ok Tomorrow ( Sunday )will be adapting the flat booster with toyota camry MC .
Stiil a way to go , just half way there.
DZ
Old 11-27-2016, 11:18 PM   #9
BillyMaysHere
Copy the image adress
Then paste it after clicking this box
Old 11-27-2016, 11:50 PM   #10
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Bryce Farted
Old 11-29-2016, 12:23 AM   #11
brickcupra
thanks will do tomorrow, today i began cutting the oil pan for clearance
Hasta la vista!!!
DZ
Old 12-01-2016, 02:21 AM   #13
Steve Zissou
Originally Posted by brickcupra View Post
hi, ok hopefully these pictures can be seen now. Thanks Bill!!!
Old 12-01-2016, 02:24 AM   #15
Steve Zissou
oil pan being cut and oil pick extended
Old 12-01-2016, 12:12 AM   #16
BillyMaysHere
you did half the steps, gotta click the little mountain box and paste each of the addresses in one by one
Old 12-02-2016, 08:30 AM   #17
brickcupra
Hi , thanks for the help. I also work as a welder and I come home exhausted!!!
Still on the works as you guys can see
enjoy the weekend !!!
DZ
Old 12-08-2016, 08:12 PM   #18
brickcupra
Hi guys ,Finally I got the pan welded, scraped and painted including sealing the pin holes with solder for a waterproof tight seal.
Here are some pictures. ( it is taking longer than usual due to being tired after work and hardly acces to the shop with no remote. I have to depend on the painter to be at the shop because he is rebuilding a studebaker. https://s20.postimg.org/ppvhv2wv1/20161204_120503.jpg
https://s20.postimg.org/4u97ju0nx/20161204_120512.jpg
https://s20.postimg.org/ip7i2av31/20161206_220513.jpg
https://s20.postimg.org/e4lbndbdp/20161207_162548.jpg
ok hope you guys enjoy the pictures
Dz
Old 12-13-2016, 07:57 PM   #19
brickcupra
Hi guys , I got the engine and trans in already, although is a mock, because I have to pull it out again to put in the clutch.
Now I encountered a problem.The brake booster interferes with the intake manifold. I need to cut down the lower support to clear the hood, still I need to figure something out with the booster, Any ideas you guys can come up with?
thanks
Dz
Here are some pictures of the engine in the bay.
https://s20.postimg.org/ypt9073dp/20161212_180056.jpg
https://s20.postimg.org/xc67imti5/20161212_180125.jpg
https://s20.postimg.org/br14v0wrh/20161212_180106.jpg
enjoy, the cold weather is killing the time to do some things
Stay warm
Dz
Old 12-14-2016, 08:14 PM   #20
BillyMaysHere
thanks
Dz
Stay warm
Dz
Old 12-13-2016, 09:35 PM   #21
Beep beep zip tang
You can buy the skinny booster reman from advance auto.
Old 12-14-2016, 12:48 PM   #22
mbolton1990
mbolton1990's Avatar
Heck ya!
Nice progress,good luck with the build.
I love the sound of a 7mgte,can only imagine one in a 240 best of both worlds really.
https://youtu.be/YjrxHqNy5CQ
" Do not be anxious about anything, but in every situation, by prayer and petition, with thanksgiving, present your requests to God. And the peace of God, which transcends all understanding, will guard your hearts and your minds in Christ Jesus. "
mbolton1990 is offline   Reply With Quote
Old 12-14-2016, 07:57 PM   #23
brickcupra
Thanks guys for the tip and support !!!!
Happy holidays !!!!
Old 12-14-2016, 08:15 PM   #24
BillyMaysHere
http://turbobricks.com/forums/showthread.php?t=201749
Old 12-14-2016, 08:22 PM   #25
BillyMaysHere
Looks like the volvo part # is 53-5890 NOT 53-5990
