Old 04-01-2021, 01:02 AM   #1
gotboost
contributor
gotboost's Avatar
Default Electric Port on my +t for the intake hose??
I'm deep in the middle of performing my +t on my '93 240. There is an electric port on the intake hose that goes between the turbo and the airbox, which I understand is a heater for the PVC system. I don't believe my 240 had such a feature. Should I just ignore it and leave it unplugged? I'm assuming that is the best option, but just wanted to bounce it off you guys.
Currently: 1993 Volvo 244 w/ 140k miles.
Previously:
1997 Volvo 850R Manual Wagon, The "Battlewagon" (the one that got away)
1998 S70 T5M SE
1985 245 +t
gotboost is offline   Reply With Quote
Old 04-01-2021, 02:38 AM   #2
James M
Banned
I just ignored it with no negative consequences. Probably a startup emissions thing like 80% of electronics on motors in the last few decades
Old 04-01-2021, 02:51 AM   #3
It heats PCV vapors so ice crystals don't form and then damage the turbo compressor.
Old 04-01-2021, 03:37 PM   #4
gotboost
contributor
gotboost's Avatar
I figured it was for something like that. I live in WA, so we really only get freezing temperatures about 20 days a year, and the 240 doesn't leave the garage on such days usually. I think I'm just going to not worry about it.
Old 04-01-2021, 11:11 AM   #5
142 guy
Yes to preventing the formation of ice in the PVC system; but, more likely to prevent the formation of ice which blocks the PVC air flow through the engine (located between the airbox and turbo it would be abnormal for air to be flowing out of the PVC tube and into the turbo). Late '70s VW Rabbits (remember them?) which first got K jet had a problem where the PVC would ice up on the air box side causing a negative pressure in the crankcase and slow evacuation of oil into the intake manifold which could be fatal for the engine. The solution was a heater on the hose to prevent icing. Really only a problem in climates where the temperature drops significantly below freezing and there is a lot of short hop driving.
Old 04-01-2021, 11:54 AM   #6
Beep beep zip tang
I don't know about PVC systems but in PCV system excess crankcase pressure gets vented to the airbox to turbo pipe, that dirty air goes through the turbo.
