ovlov760
Well-known member
- Jun 2, 2003
- Midwest - IL
A dad recently passed away. He had a '97 Volvo non-turbo 850 my mom would like to sell. It was running fine but has now developed a miss at idle. The miss only occurs at idle in Park. It seems to improve while idling in D.
Initially, there was no CEL and no codes.
Since it seemed to be worse when cold I replaced the CLT sensor. No change.
I tried a spare MAF. No change.
I replaced the aftermarket distributor and rotor with JY Bosch stuff I had on hand. I replaced the copper plugs with new NGK platinum plugs. The miss didn't go away, but fault codes appeared for a misfire on cylinder 3 and sometimes cylinder 5. The only consistent misfire codes appear for cylinder 3.
I pulled the vacuum hose from the FPR, and there was fuel in it to my surprise. I replaced that with one from an engine I parted out a while ago. Again, no change.
The miss is only detectable at idle. If I drive the car hard it's not present and the motor appears to make good power. The motor never dies.
A Seafoam really smoothed out the idle but that didn't last.
What else is there to check besides maybe compression for cylinder 3?
One other possibility I've considered is that the gas is simply bad. My dad retired in 2019. This car was the car he used to drive to work and back. After he retired he only drove it 7 miles into town and back for cigarettes I imagine. This car wasn't used for long trips or even grocery shopping. With the pandemic, I imagine it was driven even less than normal. Could bad gas cause a miss that only occurred at idle?
