Old 07-13-2021, 07:49 PM   #1
VolvoGuy123
VolvoGuy123's Avatar
Default How to plug EGR pipe to exhaust manifold?
So I have a 1995 940 T (project) I'm working on (forever) and I picked up a new turbo exhaust manifold that does not have the original (EGR) port.
Does anyone have an easy solution to plug the pipe? Thread size? Special plug, etc?
Thanks for any advice or help with this matter! I appreciate it as always.
Take care!
“Such a waste of talent. He chose money over power. In this town, a mistake nearly everyone makes. Money is the Mc-mansion in Sarasota that starts falling apart after 10 years. Power is the old stone building that stands for centuries. I cannot respect someone who doesn’t see the difference.” -F.U.
VolvoGuy123 is offline   Reply With Quote
Old 07-13-2021, 09:55 PM   #2
James M
Bored member
James M's Avatar
So your plugging the EGR on the intake side? *Should* be able to leave it disconnected, closed is it's resting state as far as I can tell
James M is online now   Reply With Quote
Old 07-13-2021, 10:10 PM   #3
The Librarian
Just get (or make) the block off plate for the intake and remove the whole system if you don't need it to pass emissions. Volvo sells a service kit but it's kind of expensive.
https://www.volvopartswebstore.com/p...36/271658.html
Old 07-14-2021, 04:38 PM   #4
Does not a spark plug fit?
Old 07-14-2021, 06:08 PM   #5
TheMenaceSD
I did not know that the block off plate was available. I have been trying to find someone that could make me one but ended up buying a 740 turbo intake manifold with the EGR port missing. Good to know if this manifold doesn't workout I can always switch back and purchase the plate.
TheMenaceSD is offline   Reply With Quote
Old 07-14-2021, 07:17 PM   #6
PCH
Just disable the vacuum to the EGR Valve so it doesn't open.
Old 07-15-2021, 04:22 AM   #7
Otto Mattik
board member
Otto Mattik's Avatar
Does Cali have strict emissions checks for any post-1975 cars ?
Old 07-15-2021, 10:25 AM   #8
PCH
Yes we do.
Old 07-15-2021, 01:10 PM   #9
OttoB
I made a plate from aluminium and plugged exhaust manifold with L12 size plug and nut. Usuallu called Ermeto fittings in hydraulic stores.
Old 07-16-2021, 10:30 AM   #10
Jack leg
Compression fitting at lowes or home depot will work, i welded mine shut.
Originally Posted by cyborgben View Post
...No sister. But if I did I wouldn't trade her for anything less than an Ls swapped 245. I have some morals....
Jack leg is offline   Reply With Quote
Old 07-16-2021, 07:05 PM   #11
TheMenaceSD
I bought this from Amazon.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It fit no problem. Will see how it holds up over time.
Old 07-19-2021, 05:14 PM   #12
lummert
lummert's Avatar
A steel metric oil drain plug?
Old 07-27-2021, 11:13 PM   #13
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Is it this easy to get rid of egr?
Deb the 940T Tina XC90 T5
Old 07-28-2021, 10:49 AM   #14
volvowagoon
volvowagoon's Avatar
Sort of, but it doesn't make the valve not leak anymore. I never saw a lot of value in deleting EGRs in gas powered street cars, but when I do, I actually delete the valve and plug both ends. It's not worth only halfway "deleting" something if you're still susceptible to it's problems.
1986 Buick Grand National - Restored to stock™
2002 Camaro V6 T5 +T - The trashy car that's fun to drive
2010 C30 T5 - The boring but trusty daily - 199k
1989 245 DL - The boring but not trusty daily - 233k
IG: @v6buick
Old 07-28-2021, 12:59 PM   #15
kyote
Living The Dream
kyote's Avatar
Never messed with one, but this works on Chevys too
https://www.clublexus.com/forums/per...-soda-can.html
Old 08-19-2021, 07:00 PM   #16
VolvoGuy123
Well, for the short term I plugged the tube (manifold end) with a high temp silicone hose cap (5/8) works good. (I swapped my exhaust manifold with a modified (ported/T3) non-egr version) but now I'm sending the OE (egr version) that came off the car to Yoshifab to essentially have them modify that one so I can just put the proper EGR manifold back on and maybe sell the (non EGR) manifold I'm temporarily using now.
In the process I've ofcourse changed all the hardware with OEM Volvo parts. (Studs, washers, copper lock nuts, gaskets)
But I have yet to expirence any negative effects from disabling the EGR system.
And the ported manifold made a huge difference in running (EGT) temperature, cool down time, overall power and also stability (virtually no more pinging, onset or otherwise!) The chipset I used eliminated like 70% of it but the ported manifold finished that job!
Car runs great now with the (td04hl) billet 20t. But i cannot wait to install my (Td06h) 20G! I'm pretty confident a properly ported manifold will flow efficiently enough for now.
Thanks for all the responses btw! You guys are great. Ttys!
Old 08-19-2021, 07:33 PM   #17
PCH
Sticking a ball bearing inside the hose is another easy and better looking way of doing it.
But disconnecting the EGR does not really have any benefits power wise and disabling the valve raises the temperature in the combustion chamber.
