Old 01-06-2012, 02:18 PM   #1
Ninja007
Default What hood will fit 1990 760?
My hood is aluminum, can I get a hood from any other model or years?
My headlights\grille used to be like this:
Now have E-codes like this:
Ninja007 is offline   Reply With Quote
Old 01-06-2012, 02:34 PM   #2
Goatman
Goatman's Avatar
Location: Albuquerque, New Mexico, United States of America
Um,
What is the question again?
Goatman
Goatman is offline   Reply With Quote
Old 01-06-2012, 02:40 PM   #3
Ninja007
Are you serious, did you read the title of the thread?
I need a replacement hood for my 1990 Volvo 760, what other models/years have the same hood?
Pics are for reference for those people that are visual and wondered what a 1990 760 hood looks like
Old 01-06-2012, 02:43 PM   #4
1988-1990 760. 1991 940SE. 1992-1998 960/S90/V90. Mechaniman in Eugene is selling/parting a 1994 960. That car has the correct hood.
Old 01-06-2012, 03:04 PM   #5
lummert
lummert's Avatar
This, but I can't confirm that a hood from a 1995-1998 960/S90/V90 will fit. But for sure a 1992-1994 960 will fit.
Old 01-06-2012, 03:41 PM   #6
Yes, they are the same. The fenders, lights, grill and bumpers changed, the hood is the same.
Old 01-06-2012, 04:55 PM   #7
Ninja007
Great info, thanks for the help. Are all of the hoods on those cars aluminum as well?
Seperate question - did all 7xx & 9xx have the same hood hinges (bolts to the hood and to the body of the car), or did some models have a different hinge style?
Old 01-06-2012, 05:44 PM   #8
miguel.760ti
miguel.760ti's Avatar
You don't need to change your hood to accommodate e-codes.
All 740/940 and pre-88 760 have the same hinges while all 88+ 760/940SE/960 have the same (although different from the 740/940) hinges with the hood struts.
1988 760 Turbo - garage queen, everlasting project
also
2016 Ford Fiesta ST - size small daily
1995 Ford F150 - size large daily
miguel.760ti is offline   Reply With Quote
Old 01-06-2012, 06:07 PM   #9
Ninja007
Good clarification on not having to change hood for e-codes, thats true. My hood was damaged in a seperate incident after I installed E-codes.
Thanks for the info on the hinges, basically is sounds like the 740 style hood and hinges go together, and the 88+760,960, v90, s90, 91' 940SE go together as a set.
Old 01-06-2012, 06:21 PM   #10
Ninja007
Old 01-07-2012, 08:00 PM   #11
gmtgmt
gmtgmt's Avatar
Just to vertify the Part number for the hood is the same for all 88+ 760, 960, S/V90
gmtgmt is offline   Reply With Quote
Old 01-07-2012, 09:02 PM   #12
RepairmanJack
South-City Volvoman
RepairmanJack's Avatar
An S/V90 hood would work? You sure? The fenders, grill, and nose configuration changed quite a bit on the 90-series.
One thing is for sure, a 7/940 hood would *not* work. The hood is shorter because the 7/940s have a cowl between the windshield and hood.
_________________________
Feedback Profile http://forums.turbobricks.com/showthread.php?t=249486
RepairmanJack is offline   Reply With Quote
Old 01-08-2012, 06:34 AM   #13
gmtgmt
gmtgmt's Avatar
yes i have both a early 960 and V90 they are identical
Old 01-08-2012, 01:40 PM   #14
To put it to rest once and for all. Here is a 1997 V90 that I used a blue hood from a 1989 760 as a replacement. I pulled the 760 hood at the wrecking yard so I know exactly what it came off. The hoods are all the same as I said in my post above. 1988-1990 760. 1991 940SE. 1992-1998 960/S90/V90.
Photobucket
Photobucket
