Old 01-02-2021, 12:38 AM   #3126
LC4CARL
Aero challenged
LC4CARL's Avatar
After the initial install of the bigger turbo, I was intoxicated with +/- 14 psi blasts that settled to 12.
Boost video!
But then I messed it up. I played with the MBC and actuator adjustments. Because, I don’t know.
@PDXvolvo on IG
B21FT with a T3/T4, STS coil-overs, T5 trans.
Old 01-02-2021, 12:49 AM   #3127
LC4CARL
Aero challenged
LC4CARL's Avatar
In the six months since I have endeavored to restore balance to the universe...
Tonight.
I fell back upon my favorite exercise: the visual inspection.
Exhibit: A
Old 01-02-2021, 12:59 AM   #3128
LC4CARL
Aero challenged
LC4CARL's Avatar
I elected to install a metal gasket between the turbo and the waste gate. My hypothesis is that the bottom edge of WG valve was seated on the edge of the gasket.
Exhibit B:
Old 01-02-2021, 01:06 AM   #3129
LC4CARL
Aero challenged
LC4CARL's Avatar
If...
The valve was sitting on a +/- .020” gasket, would that have a meaningful reduction in boost?
Could this have “changed” in any way since I installed it?
Not likely...
Time for a test drive.
Old 01-09-2021, 08:07 PM   #3130
LC4CARL
Aero challenged
LC4CARL's Avatar
No change after WG gasket removal.
MBC in or out, no difference.
Pulled manifold reference hose from actuator. Again, no change.
Old 01-09-2021, 11:54 PM   #3131
Quin
ಠ_ಠ
sounds like the same process i went through when actually my wastegate adjustment was just dumb.
Old 01-10-2021, 01:17 AM   #3132
LC4CARL
Aero challenged
LC4CARL's Avatar
My car hates me...
Old 01-10-2021, 04:10 PM   #3133
122power
dude
122power's Avatar
Uh oh. Just dont blow it up eh.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 01-10-2021, 06:06 PM   #3134
LC4CARL
Aero challenged
LC4CARL's Avatar
Nah, I read on internet about this guy that said is cousin was running 20 psi with no problems...
Old 01-12-2021, 05:16 PM   #3135
122power
dude
122power's Avatar
Cousin darrel?
Old 01-12-2021, 07:12 PM   #3136
LC4CARL
Aero challenged
LC4CARL's Avatar
LOL.
Ordered an actuator with a 22 lb spring and a chip to raise the redline to 6,700.
Go big.
Old 01-12-2021, 10:18 PM   #3137
122power
dude
122power's Avatar
Cool shirt! Who had the chip?
Old 01-12-2021, 11:25 PM   #3138
LC4CARL
Aero challenged
LC4CARL's Avatar
Simon or “sbabbs.” Great guy. Pretty excited.
Old 01-13-2021, 12:13 AM   #3139
I suspect your m47 will not be long for this world
Old 01-13-2021, 11:45 AM   #3140
LC4CARL
Aero challenged
LC4CARL's Avatar
Hoping for 200 whp with the boost at 14-15 psi. Saw about 150 in March of '19 (Has it really been that long?) with the "Turbo 1" set-up and 10 psi.
Did the coil-over suspension and "Turbo 2" upgrades in '20. Hard to believe. Hoping to do the T5 this year. Time flies.
Old 01-13-2021, 10:51 PM   #3141
Vol242vo
Keep it clean...
Vol242vo's Avatar
Love your Wagon Carl, it really has taken a new life over the past few years! It’s
a good lookin’ 245!
Derek
1 Owner - 85k mile 1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 01-13-2021, 10:57 PM   #3142
122power
dude
122power's Avatar
T5?! That means the price will go up!
Old 01-16-2021, 10:15 PM   #3143
LC4CARL
Aero challenged
LC4CARL's Avatar
a good lookin’ 245!
Thx boss. She’s a “30 footer.” But, as my brother says, she’s family.
Old 01-16-2021, 10:15 PM   #3144
LC4CARL
Aero challenged
LC4CARL's Avatar
Nobody wants it...
Old 01-17-2021, 12:41 AM   #3145
LC4CARL
Aero challenged
LC4CARL's Avatar
The DL in its native environment: On a jack stand.
New ATP actuator has a MASSIVE spring in it.
In order to line everything up, we had to re-clock the turbo. Which sucked.
Old 01-17-2021, 12:48 PM   #3146
122power
dude
122power's Avatar
Massive.
Old 01-17-2021, 03:08 PM   #3147
LC4CARL
Aero challenged
LC4CARL's Avatar
Old 01-17-2021, 08:55 PM   #3148
LC4CARL
Aero challenged
LC4CARL's Avatar
Well, on the positive side we have absolutely confirmed the cause and origin of my low-boost condition. On the negative side, I am apparently a very slow learner when it comes to the functionality of the MBC. For whatever reason I believed that I should over-spring the target pressure, then bleed it off with the MBC for fine-tuning. Obviously the inverse is true.
Do you think 25 psi is too much for an M47?
Old 01-17-2021, 11:46 PM   #3149
Quin
ಠ_ಠ
just shift nice into third.
Old 01-18-2021, 12:49 AM   #3150
LC4CARL
Aero challenged
LC4CARL's Avatar
Chicks dig exploding transmissions...
