3D Printed Parts Thread
Might as well post up my contribution to the cause. I have been rocking both of these items on my car since the summer, and there has been zero degradation or explosions. I HIGHLY recommend using TPU at 100% infill in order to achieve the proper hardness. The swaybar bushings were done with 95A and the endlink bushings were done with 85A. Flexibles are REALLY tough to print, so be warned if you've never done it before. You print the swaybar bushings and then slice them along the side in order to get them over the bar. That's another reason to use 100% infill.
https://www.thingiverse.com/thing:4342586
TPU are thermoplastics, so they WILL soften with high heat. They won't melt, but they'll probably get softer. I live in Canada, so I was able to test these on days up to 30*C, and everything has been fine...considering they're hidden under the car. I don't know what will happen if you're stuck in traffic, in LA, on a freshly paved highway. I have NO idea what will happen if they're used in freezing temperatures (my car is a spring/summer/fall cruiser). Use at your own risk.
The second thing I made was an addition to the Blippy cupholder for 240s. I prefer can drinks to coffee, so a cupholder that couldn't hold cans was no use to me. I made a quick little can adapter that slots into the Blippy design to allow can use. It's removable too, just in case I ever feel like having a coffee or fountain drink :). A hole is needed in the bottom to prevent vacuum lock (it fits very close to the can), and I didn't notice until after it was uploaded on thingiverse.
https://www.thingiverse.com/thing:4716183
On sale or was it an open box. My microcenter shows they did have them for 259, but they were open box?
Guess I'll add my stuff as well.
Grab handle covers!
Before:
<img src="https://cdn.thingiverse.com/assets/24/97/b8/77/2e/D0799726-8A73-4A2D-B852-456D3BE25479.jpeg" alt="img src 40%" title="img src 80%" width="50%" height="50%">
After:
Painted the whole lot with matte black spray paint.
<img src="https://cdn.thingiverse.com/assets/b8/fd/93/6e/31/103AC368-B725-427F-80F5-82B94F33E896.jpeg" alt="img src 40%" title="img src 40%" width="50%" height="50%">
<img src="https://cdn.thingiverse.com/assets/e5/28/83/a9/a6/005C435E-9974-40B4-9C27-D7FA26B03325.jpeg" alt="img src 40%" title="img src 40%" width="50%" height="50%">
https://www.thingiverse.com/thing:4970473
I'm currently working on a center console made from PETG but my god is it an undertaking. The struggle is getting it all to fit seamlessly since my largest build plate can only accommodate ~9 in.
Dude if you are successful I would totally do this.
Is it a copy of the stock one? Or are you integrating some changes, like maybe a charge port or something.
My center console has returned to the dust from which it came. I need one but don't want to spend on the knockoffs. Would love a printable console.
As my contribution I'm trying to print some plates that let you use standard 1156/1157 bulbs in the tail lights. Get rid of the stock housings forever.
Problem is I'm learning 3d modeling from scratch and have very little time to devote to it.
Oh that's a huge undertaking indeed.. Getting a nice finish afterwards is quite the struggle too. Though you can potentially make a way sturdier part. With thicker walls + a few % infill.
It has to print in pieces. I'm developing a way to interlock the pieces together in a nice way. Anyway, it's going to take a while but I thought it'd be cool
Anyone have any other requests?
The center console would be legit cool af for me.
As far as making a strong joint between pieces, I like this guy's approach. These joints have to be airtight and very strong. He does the jb weld on all his builds.
https://www.youtube.com/watch?v=4_4tu4rAtgI&t=533s&ab_channel=HexiBase
https://www.youtube.com/watch?v=sV3P6nMRGQs&ab_channel=HexiBase
He doesn't have a video explaining his jointing method, but usually talks about it in some form when he's glueing stuff together.
I've got a few things in *.STL format ready:
Manual window crank with extended reach to allow for clearance of larger speakers
Center dash faux speaker cover
245 Visor clip
5 1/2" front door speaker ring
CAE style shifter knob
245 rear seat release latch ('88)
Shifter boot lower trim with clips for leather cover
In Progress:
True round headlight conversion for any 7" lamp with separate DRL LEDs
240 snow caps
I did not see it in this thread so I will probably model up and 3D print a rear main seal installation tool soon. Im just doing this to make installing my seal a little easier, but if anyone has any 'feature' request let me know.
We should make a drive of some sort if anyone would like to post their 240 related 3d prints if they choose to release them. So we can have it all in one place. Just to localize them for the future of volvo.
