Old 02-11-2011, 09:26 PM   #1
JackEJ11
Default will this fuel rail work?
Hi guys,
Just wondering if a fuel rail off a 87 740 gle will work on my 91 940t? I don't know if my car has the cold start injector though. I believe it's lh 2.4?
JackEJ11 is offline   Reply With Quote
Old 02-11-2011, 10:08 PM   #2
swiftjustice44
Central Coast Brickyard
swiftjustice44's Avatar
The rails are the same. Cold start injector would be the issue.
swiftjustice44 is offline   Reply With Quote
Old 02-11-2011, 10:11 PM   #3
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
It really dont matter. the problem will be if the 740 rail has a cold start and the 940 does not. If the 740 does not have a cold start, and the 940 does, just leave the CS installed and run the rail without it hooked up. It will start just fine.
I need to ask, does it have a 16v since its a gle? Or when did the 16v head come on the cars?
962j 815/692@27psi
THIS IS FORSALE V
Old 02-11-2011, 10:34 PM   #4
JackEJ11
Only cars that had cold start, were the cars that had regina right? I don't know if my 940t would have one.
Old 02-11-2011, 10:35 PM   #5
JackEJ11
Good question, The 16v engines only came in the 89/90 GLE cars.
Old 02-11-2011, 10:39 PM   #6
nathaninwa
nathaninwa's Avatar
Good, my 91 940T had a cold start....when I built the sheetmetal intake with billet rail I deleted it, car ran just fine!
Old 02-11-2011, 10:45 PM   #7
JackEJ11
It's the injector under the rail with a blue clip right? If so then my 940t has one.
Old 02-11-2011, 10:49 PM   #8
nathaninwa
nathaninwa's Avatar
Yep, not needed....might take a few extra cranks to start. All my intakes delete the CSI. Just leave the injector bolted in and run the rail without.
