Old 04-11-2021, 06:16 PM   #26
Msi
Originally Posted by Acke View Post
IIRC my installation manual has the strut extended at that point. Fully compressed would make no sense if the spring is under preload only. I have also considered trying normal, cut HD rear springs instead for a slightly softer spring rate. Don't want to go too soft since I have 8kg/mm in the front.
I'll take the back apart and do it again. Double checking that the shocks are extended all the way at that step. It may just be the case that mine were already screwed into the base partially and thus not fully extended.
Msi is offline   Reply With Quote
Old 04-12-2021, 11:29 AM   #27
GeneralBurrito
GeneralBurrito's Avatar
There is also the "DC" line from classicswede that I've considered getting for my 240, but I don't know much about their quality and how they compare to the BCRacing kit. But the ones from CS do seem catered to the RWD Volvo specs instead of just getting parts and putting them together like BCR does.
https://www.classicswede.co.uk/Coilo...5_1625033.aspx
Old 04-12-2021, 12:55 PM   #28
thessejway
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
thessejway's Avatar
Originally Posted by blkaplan View Post
They don't have any R&D into them. They take their generic off-the-shelf stuff and slap it in a box.
For BC, it's a volume game. Quality isn't a consideration.
They have an extra caster edition.
Hey that's my car! I would just like to add that this was caused by the lower bolt on my brake caliper backing out and the caliper lodging into the wheel causing to to lock up. The coilover didn't just break on it's own.
I will agree that their quality isn't the best and I have already swapped out the BC rears because of the bouncy ride.
If I could go back in time I wouldn't have bought them, mostly because the stiff ride doesnt match the rough roads around where I live.
____________________________________________
1993 945t Build Thread
thessejway is offline   Reply With Quote
Old 04-12-2021, 06:47 PM   #29
Msi
What did you swap the rears to? Details details details
Old 04-13-2021, 10:50 AM   #30
thessejway
¯\_( ͡❛ ͜ʖ ͡❛)_/¯
thessejway's Avatar
Just stock springs and dampers for now and I raised the front ride height to match
Been debating whether or not I want to do a lift so there may be Cherokee springs going in. For now I'm just using the car to cruise around occasionally so stock springs are doing fine
