Old 04-14-2021, 12:31 PM   #1
Dvroofer
Dvroofer's Avatar
Default Single wire alternator.. exciter wire ?
If someone could help me out with where and how to wire in the exciter wire when installing a single wire alternator. Iím sure it may have been covered but my searches are coming up short. I will be attempting to wire in a single wire alternator to my 1991 240 lh 2.4 b230f
Thanks
Dvroofer is offline   Reply With Quote
Old 04-14-2021, 12:39 PM   #2
JohnMc
JohnMc's Avatar
Single wire alternators just need that single wire. Some of them use an external jumper to the exciter wire from that terminal, some do it internally.
I stuck a GM alternator on my PV, and with the wiring I was able to choose from 1, 2, or 3 wire installation. I chose 3 wire:
1) Heavy 12+ charging lead to the battery
2) Exciter wire to the Volvo charging warning bulb (maintain warning light functionality)
3) Voltage reference (typically pulled from #1, but I chose to reference the far side of the 50 year old fuse block)
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 04-14-2021, 03:49 PM   #3
Dvroofer
Dvroofer's Avatar
My question would be after I land my big +red wire to the alternator and ground it, What do I hook my exciter wire to. Iím under the impression it needs to be less than 12volts. Can I eliminate this wire without issues? Or do I need it functioning?
Thanks
Old 04-15-2021, 10:17 AM   #4
Dvroofer
Dvroofer's Avatar
Problem solved. Scrapped that single wire idea and swapped in a 100amp unit. Will wait to get a mechmen and a d.Barton bracket system
Old 04-15-2021, 04:33 PM   #5
Beep beep zip tang
I have a "system" relay that I installed that energizes off the blue wire that runs the coil. I have the exciter wire hooked up to that, so no idiot light functionality. Experts on here said it would cook the alternator but no problems in several years of operation. I have a digital volt meter/USB port in my row of switches to monitor output. It always runs 13.5-14.2 volts even at full load, electric fan, headlights, blower etc. I have the denso 100 amp in my 242.
Old 04-15-2021, 08:36 PM   #6
Dvroofer
Dvroofer's Avatar
I appreciate the information. I had no issues with the 100amp unit in the past 2 days. What I was going to do was take the 200 amp unit off my Chevy truck and use it because I was in a pickle. It didnít come to that but I did find a rubber plug on the alternator that has two connectors. I assume I would of been able to find out what wire to what connector.
Iím not 100% on what mechmen I am going to order in the future . They have different wiring configurations as in single wire /Chevy 4 wire. The unit Iím looking at is a compact 240 volt but will need a special bracket for a tension pulley. The reason for a mechmen:
I plan on ac, electric fans,extra fog lights, hids,large stereo (not stupid but large maybe 2000 watts total), 1000 watt inverter, PA system.
I have a capacitor ready to go in and an optima battery.
Old 04-16-2021, 04:35 PM   #7
Dvroofer
Dvroofer's Avatar
Thanks for everyone’s help. This board has saved my ass as always
