Old 01-14-2022, 10:01 PM   #1
getouttamyway
Default 240 firewall pass through?
I need to run a wire through the firewall to switch on a set of fog lights. I see posts mentioning that the factory left some ports and/or grommets specifically for this purpose but I can't find them for the life of me. Can anyone point me to a pic?
I've got a 1990 240 DL wagon with an automatic.
getouttamyway is offline   Reply With Quote
Old 01-14-2022, 11:07 PM   #2
white855T
There is a plastic tube behind hood latch. The hose has a rubber cap. Follow the latch wire and you'll see it.
Old 01-15-2022, 02:38 AM   #3
mblue240
mblue240's Avatar
This is the tube, I just added it to my 89. Not all years got them, but I can't remember if it's 90+ or 93 only. If you don't have the tube there is a solid grommet in it's place.
20211217_131126 by M. Blue 240, on Flickr
20211217_131330 by M. Blue 240, on Flickr
Old 01-15-2022, 05:04 PM   #4
getouttamyway
I see. Mine has two grommets on the driver's side that are both used. One for the hood release cable and one with a vac line (cruise?). On the pass side it looks like there's one for the rear window squirter and one unused grommet. Was hoping to have an extra port on the driver's side.
On the pass side I actually need that since I relocated the washer tank to the rear and ran the wires jankily through the main harness hole in the firewall.
I want to wire front fogs into the rear factory fog switch. Let me know if you guys have any other ideas!
Old 01-15-2022, 07:53 PM   #5
ermit71
ermit71's Avatar
Poke a hole in the grommet and feed the wire through... party on
Feedback
ermit71 is online now   Reply With Quote
Old 01-15-2022, 09:17 PM   #6
Radtap
Radtap's Avatar
Locate wiring harness grommets or drill hole and install grommet, some room behind the pedals, gives you a spot for future wires
Feedback
Radtap is offline   Reply With Quote
Old 01-16-2022, 12:05 AM   #7
OldCarNewTricks
OldCarNewTricks's Avatar
https://www.autozone.com/lighting/gr...E&gclsrc=aw.ds
Old 01-16-2022, 09:28 AM   #8
white855T
90-93 would have tube. So ops car should have it.
