TurboBrick940
- Jan 13, 2003
- 50/50 VA/NC
Ladies and Gentlemen,
I found a dirty little secret involving my car and a little thoughtful tuning In the spoolup range (0-10psi). We put a little extra timing in (I'll post my ignition map shortly), and and fattened it up a hair...wow! My car has always had a lean spot at low rpm/high load. Upon adjusting the advance in the ignition table in degrees (0psi)1-2(Boost Threshold)3-2(10psi)-1-0, and putting a little more fuel in down low as well, it was amazing to see the difference in spool. Not to mention the fifty peak lb ft. of torque we found...The car hits so HARD at 3000rpm...It'll boil a little smoke off the tires halfway through an intersection if you hammer the gas at the light.
Something to think about,
Eric
Eric
