Old 07-05-2021, 01:46 PM   #26
OldCarNewTricks
OldCarNewTricks's Avatar
Originally Posted by Janspeed View Post
have a look at a TruTrac diff. It's a torque sensing gears-only diff, no clutch pack inside.
If your Volvo has a 1030 axel / Dana30 rear end there are options from the Jeep aftermarket that will fit.
http://forums.turbobricks.com/showthread.php?t=55095
I've heard excellent things about the TrueTrac. My automotive teacher recommended one for my my truck, actually. Said it's the best hybrid between clutch style and a locker.
Old 07-05-2021, 01:49 PM   #27
OldCarNewTricks
I did a quick search to see what’s out there. The 912A-585 seems to be the one they sell for jeep fronts.
The first ones i saw were clearance 912A398, low preload for jeep front. I am guessing that new number is low preload but with the harder case and 6 case bolts.
The 398s worked great in snow, not great for racing. They are part of the reason for the bad early reputation.
The old high preload number was 912A411. 3 larger case bolts like the 398 suffix diffs.
The new (2007) high preload diff with 6 bolts and harder case is 912A588.
https://www.summitracing.com/parts/dtl-912a588
*edit: it will say “3.73 up”. Ignore that. The one case size fits all volvo ring gears for 1030 and 1031.
Regarding that early post: I have a collection of several variations on pinions now. I haven’t posted pics, but i can do that with this info too.
I'll talk to my friend about the 912A588. The ONLY thing I've heard about the torsen style differentials (TrueTrac), is that in cases where one wheel is off the ground, because there is no spring pressure between both sides, that the wheel in the air will spin freely (basically open diff in this case). For what we are doing, I think we should both be fine with this style of differential.
Old 07-05-2021, 09:12 PM   #28
283SD
Y'all are over thinking this. The car has it's limits as with any car. Want to go off roading get a Jeep/Hummer/Chevy, Ford, GMC, Toyota ect. Something with 4X4 ?. Been there there done that. You are getting over complicated!!!
Old 07-05-2021, 09:31 PM   #29
mikep
The MP
mikep's Avatar
Why LS swap a 242 when you can get a camaro, right? Wrong. He wants to camp and hit some light trails in a wagon
Old 07-05-2021, 09:33 PM   #30
mikep
The MP
mikep's Avatar
A Truetrac is nothing like a locker. Also, a truetrac will pull with one wheel on ice. And any unmodified clutch diff can go up in smoke with a wheel in a ditch. I can post pics of those bad parts, too.
Old 07-05-2021, 09:33 PM   #31
OldCarNewTricks
If we stay away from difficult traction situations, we should be fine. We aren't mudding/rock crawling, we are just looking to go camping in some offroad areas.
Old 07-05-2021, 10:12 PM   #32
Ain't nothing wrong with running some dirt roads in a Volvo.
They were born and bred on a dirt road after all.
how psi stock cna sprout?
Old 07-15-2021, 04:56 AM   #33
Otto Mattik
board member
Otto Mattik's Avatar
Im running 14.5mm Lesjofors up front & 14mm on the rear(13mm stock) on a late 245, without changing much of the dynamics or camber, etc...it gives plenty of support with around 1"(+/-?) of lift while retaining stock handling characteristics. It works fine on dirt roads or trails.
Old 07-16-2021, 04:32 PM   #34
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Stock 245 Turbo with Hydra rims and 205/55R16 tires. Photo taken in the only smooth portion of the road I was on. The rest of the road looked like a minefield with 3-4" deep potholes every 2-3 feet that you'd have to play dodgeball with. Car did fine. Got dirty from all the mud splashing up on it, but no problems otherwise.
As an example, some mud splatters on the bumper...
@john242ti on IG
Old 07-16-2021, 04:54 PM   #35
OldCarNewTricks
Sweet! Thanks for all the information, photos and words! Very encouraging, excited to go out and explore.
Old 07-24-2021, 03:28 PM   #36
OldCarNewTricks
So I've finally had the opportunity to measure what he currently has on his wagon. Seem he has rear springs that measure somewhere around 14.5mm. I think that means he already has overloads, but somehow his rear end is still sagging down...
Old 07-24-2021, 03:40 PM   #37
Are they the progressive springs with tighter coils at the top?
Old 07-24-2021, 03:46 PM   #38
OldCarNewTricks
Yes, they look to be those.
Old 07-24-2021, 03:53 PM   #39
I've sagged stock wagon springs but never the original IPD overloads.
https://forums.turbobricks.com/showthread.php?t=211056
Old 07-24-2021, 04:47 PM   #40
OldCarNewTricks
I think the measurements of these matches the cheap Husky brand ones. Are the IPD a better bet? Or maybe adjustable mounts?
Old 07-25-2021, 04:27 AM   #41
gotboost
contributor
gotboost's Avatar
I took my '85 245 all the way to Alaska via the Alcan. It did great. I bought some RV foam and made a bed out of the back. I also built some bug screens than fit into the rear window tracks. It was an awesome trip, and the perfect car.
Currently: 1993 Volvo 244 w/ 140k miles.
Previously:
1997 Volvo 850R Manual Wagon, The "Battlewagon" (the one that got away)
1998 S70 T5M SE
1985 245 +t
gotboost is offline   Reply With Quote
Old 07-25-2021, 05:57 PM   #42
hessam69
So,
How does the truetrac work with the tone ring for the speedometer?
Old 07-25-2021, 09:33 PM   #43
James M
Bored member
James M's Avatar
I've got a similar setup for my 84 245, foam mattress cut to the right shape (and folds up) plus bubble wrap insulating sheets covered in black cloth for the windows.
