Old 07-23-2021, 02:24 AM   #1
fastcomet
Default Whos renting valve shim kit>
Im estimating 3.15-3.20 mm shims. Head has had a valve job and the new cam base circle is .015 bigger. Ive searched IPD web site but could not find the kit. Id be willing to buy a set if possible too. Anyways thanks for the help.
fastcomet is offline   Reply With Quote
Old 07-23-2021, 07:39 AM   #2
volvowagoon
volvowagoon's Avatar
I noticed that too. Hopefully there's still a solution whenever I need to dig into my head. Good luck.
1986 Buick Grand National - Restored to stock™
2002 Camaro V6 T5 +T - The trashy car that's fun to drive
2010 C30 T5 - The boring but trusty daily - 199k
1989 245 DL - The boring but not trusty daily - 233k
IG: @v6buick
Old 07-23-2021, 09:27 AM   #3
cmsuter
What a coinkie-dink. I literally just emailed IPD yesterday about this. They said they no longer offer the kit. I'm also looking to do this to both of my 240's in the near future.
cmsuter is offline   Reply With Quote
Old 07-23-2021, 10:00 AM   #4
white855T
Just take measurements and order the specific shims you need.
Old 07-23-2021, 10:12 AM   #5
cmsuter
But then that involves the car being down for a week or so. Obviously if that's the only option then there isn't much of a choice but it'd be a lot more convenient to just get a kit.
Old 07-23-2021, 10:26 AM   #6
fastcomet
I have measured and Im coming up with 3.15-3.18mm shims, which Ive searched for that size and have not found anything. With my thinnest shim I dont have any lash. Im thinking about sending head back to machine shop. I believe they did a valve job and did not take anything off of the valve stem. Its been a head ache with them, they lost the camshaft caps and insisted I didnt have them on the head. But after a bunch of back and forth they came up with them.
Old 07-23-2021, 10:27 AM   #7
fastcomet
[QUOTE=cmsuter;6202155]But then that involves the car being down for a week or so. Obviously if that's the only option then there isn't much of a choice but it'd be a lot more convenient to just get a kit.[/QUOT
I noticed that kgtrimning sells a kit but man probably take 2-3weeks to get it.
Old 07-23-2021, 10:44 AM   #8
kyote
Living The Dream
kyote's Avatar
Silly question, but did they install the valve hushers? This would throw off your measurements.
Sounds like best option is to take the head and new cam to (maybe another machine shop?) and have them tip the valves to set the lash.
I have the shim kit but a long way from you!
Old 07-23-2021, 10:57 AM   #9
culberro
culberro's Avatar
My guess is either measuring with hushers or the machine shop sank the valves into the head and didn't tip the valves and set the stem heights correctly.
The tips of the valve stems should be ~25.75-26mm down from the valve cover surface (cam centerline) for a stock base circle camshaft.
Old 07-23-2021, 10:59 AM   #10
That's what the post office is for!
how psi stock cna sprout?
Old 07-23-2021, 11:19 AM   #11
Dvroofer
Dvroofer's Avatar
Would a machine shop be able to take thicker shims and cut to size?
Dvroofer is offline   Reply With Quote
Old 07-23-2021, 11:44 AM   #12
Not cost effectively, they're only a couple bucks each.
Old 07-23-2021, 12:01 PM   #13
culberro
culberro's Avatar
One thing to look out for, when going with thinner shims an aggressive cam lobe can actually hit the edge of the bucket. This can only happen when the shim is thinner than the outer lip height on the bucket (around 2.8mm I think)
While most volvo parts suppliers do not sell shims this thin, you can definitely buy them... but be aware of the issue.
Old 07-23-2021, 01:14 PM   #14
The Librarian
I have a shim kit available to rent. The standard kit only comes with 25 sizes, 3.3mm-4.5mm and 4 of each size. I filled out the standard kit (34 sizes) with 5 of each size but there's only one size smaller than standard. Smaller and larger shims are available but need to be ordered.
I also include installation tools, lash caps and OE hushers (aftermarket ones don't last very long) with the shim kit and a free solid cam gear dowel pin with the kit rental. Because of the large number of shims and the tools I need a sizable deposit to rent to kit.
http://hiperformanceautoservice.com/...mKit&Tools.jpg
Old 07-23-2021, 01:19 PM   #15
culberro
culberro's Avatar
I have a shim kit available to rent. The standard kit only comes with 25 sizes, 3.3mm-4.5mm and 4 of each size... Because of the large number of shims and the tools I need a sizable deposit to rent to kit.
I'm waiting for everyone to complain about a $500+ deposit on the shim kit. All those $4 shims add up really quick when it's basically $20 per size/square in the box plus nearly unobtanium tools.
Old 07-23-2021, 01:25 PM   #16
That's more than I paid for my car!
Old 07-23-2021, 02:00 PM   #17
The Librarian
Not to mention ~$50 to ship it both ways with insurance.
Old 07-23-2021, 02:10 PM   #18
+ the rental fee and any shims that are used.
Old 07-23-2021, 02:11 PM   #19
cosbySweater
cosbySweater's Avatar
https://store.vacmotorsports.com/vac...s38-p2426.aspx
1995 Porsche 993
2013 VW Passat TDI
Old 07-23-2021, 02:29 PM   #20
$3.39 ea
https://www.ipdusa.com/Catalog/Index?searchwords=shim
Old 07-23-2021, 02:58 PM   #21
white855T
If the hushers are installed, you will not get the correct measurement. Pull lifter off to see if the husher is installed.
Old 07-23-2021, 05:13 PM   #22
cosbySweater
dont see any in the size he was looking for so there is that
Old 07-23-2021, 05:17 PM   #23
fastcomet
I appreciate all the advice. But no the hushers were not installed. Basically when head came back all the parts were in a box and valves tapped onto the head so they wouldnt fall out. I set the cam up without the hushers(dont plan to run them.), using a B cam. The base circle size of the B cam is about or close to the original M camshaft. Today, I took the head back to the machine shop, they want 500 to trim down the valve stems (I paid 300 already). So, I called for the manager and after a long talk they are going to fix the head, he was cool about it at no charge. But the guy doing the head is a real butt (to put it nicely). Well see what happens, they claim it was my fault not telling them I wanted a complete job.
Old 07-23-2021, 06:34 PM   #24
Dvroofer
Dvroofer's Avatar
Doesn’t sound like your fault at all. Sounds like they got schooled on the proper way to do the job correctly and made it right. Glad to hear it’s worked out.
Old 07-23-2021, 07:15 PM   #25
PCH
I thought if you press on the shim bucket with some force you compress the husher enough to get the correct measurement. Wrong?
