Hello all!
A few months ago I did a turbo swap on my '91 740, below are the specs of configuration:
- TD04-13c running currently at 10psi peak
- AW70L with an aftermarket Transmission Cooler
- Turbo ECU and EZK Chipped with TLO's chips
- IPD Turbo Cam & Cam gear running 6 degrees advance.
- Blue 34.6lb (0280155830) injectors
- 93 Octane fuel
I know that the AW70L is a pretty weak transmission, and that the B230F has a higher compression ratio -- but what's the limit with regards to boost on the engine before it detonates and blows itself up? What are some other things I can do to this car to beef it up, and make it a bit safer?
- 93 Octane fuel
