Old 01-13-2011, 10:37 AM   #1
Cl1n7R1X
Exclamation How hot is too hot for an aw71 to run?
Just wondering who if anyone has installed a temp gauge on their gearbox and what would be considered too hot to run one? Average running temp to maximum? Hoping to make the burnouts on the 29th but need to pull my finger out and get a couple of things done. Mainly exhaust and welding the diff. But gearbox is what i need to know about as i don't want to fry it first day out. Thanks in advance all :-)
1985 BMW E28 M528i, 5 Speed, Lsd, Recaros.
1993 SAAB 900i Turbo 16v 5 Speed.
1988 VOLVO 245, B230ft, Auto, Welded Diff. Burnout Car.
I own so many cars, because i can. XD
Cl1n7R1X is offline   Reply With Quote
Old 01-13-2011, 11:04 AM   #2
varg
kludgemeister
varg's Avatar
I can't tell you a temperature but I can tell you that if you don't already have a huge transmission cooler with a fan you need to get one or your AW will be dead after a few burnouts.
'85 244DL B21FT swap (gone ), ->Project thread
'91 E30 318is, M20 swapped, turbocharged. project in progress.
Kawasaki ZRX1200R
varg is offline   Reply With Quote
Old 01-13-2011, 11:17 AM   #3
Cl1n7R1X
getting one sorted this weekend. Same as the chevs are running. I couldn't find a trans temp gauge but i've got an oil temp gauge ready to be plumbed in ( need to find a t piece to suit) Obviously if it goes the the high end of the gauge i'm backing off right away. The cooler i'm getting is 45 x 45 fan forced.
Old 01-13-2011, 11:40 AM   #4
2fast4u
2fast4u's Avatar
If this were true, my tranny would've been dead a long time ago. Countless drag runs(all wwithin 1 minute of each other, big burnouts on the weekends for the ricers, and lots of practice launching and my transmission is fine.
But yes, get a cooler.
1993 940T
2005 RSX Type S
Originally Posted by badvlvo View Post
Sounds like you are afraid of the horse cock Kenny.
I will freely admit that yes, yes I am. and I'm not ashamed of that fact.
Originally Posted by MrBill View Post
im skeptical... i hope this isnt your last post. famous last words, rite? "anyone JB welded this?"
2fast4u is offline   Reply With Quote
Old 01-14-2011, 04:29 PM   #5
25psi
25psi's Avatar
Also, getting a good ATF that can handle heat is just as important.
-Jim
90' 764T(sold)
25psi is offline   Reply With Quote
Old 01-14-2011, 04:32 PM   #6
2fast4u
2fast4u's Avatar
somebody answer this dude's question lol. I too am curious
Old 01-14-2011, 04:50 PM   #7
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Done the accumulator mod?
Old 01-14-2011, 04:58 PM   #8
745 TurboGreasel
745 TurboGreasel's Avatar
Feedback
Old 01-14-2011, 07:07 PM   #9
cargod78
cargod78's Avatar
I use Wolf's head super synthetic in my aw71, seems to work great.
1992 745t 3" Downpipe back exhaust cat delete, 94 squirter motor, MBC and 15G. ghetto drop (cut springs)
1998 V70 XC bone stock
1976 Honda CB550 Cafe
cargod78 is offline   Reply With Quote
Old 01-14-2011, 09:52 PM   #10
Cl1n7R1X
yeah accumulator mod done.
Old 01-15-2011, 04:55 PM   #11
pwschuh
Rolling...
If I was stressing an automatic I would have a trans temp gauge at a minimum. Once you cook it beyond a certain point (varies with fluid) it rapidly loses its ability to cool. Cooler is a must for performance applications.
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 01-15-2011, 08:50 PM   #12
Cl1n7R1X
ok i know i need a gauge. I know i need a cooler. What i need to know is who else has one and what temps do they run at? I have both a cooler and a gauge. And accumulator mod have been done. I know someone with a 900 series put a temp gauge on his box but i don't know his name.
Old 01-15-2011, 10:44 PM   #13
Joe P
Not a AW but I ran my truck with some very hot mods and auto. The RE47 would take a dump after anything over 210. If I kept it under 190 it would live 30K or so behind 1100 ft/lbs. If the flid is over 225 or so it no longer can cool and things go south from there. The converter is the biggest heat maker.
I'd shoot for under 180 for high stress with dino and under 190 with synthetic.
On the flip side under 150 or so is almost as bad.
Joe P is offline   Reply With Quote
Old 01-16-2011, 12:47 AM   #14
Cl1n7R1X
thanks mate that was the sort of info i was after
Old 01-16-2011, 01:07 AM   #15
2fast4u
2fast4u's Avatar
where are you guys putting the temp reader for the gauge?
Old 01-16-2011, 03:12 AM   #16
Cl1n7R1X
mines going to be inline coming out of the gearbox to the trans cooler.
Old 01-16-2011, 10:25 AM   #17
Joe P
The best place is either on the outlet line as close to the box as practical or on the valvebody which means serious mods to fit.
Jegs used to sell a really nice thermostatically controlled cooler with a true bypass. Wasn't cheap but they worked well.
Old 01-16-2011, 08:31 PM   #18
pwschuh
Rolling...
Depends on the fluid. Synthetic is going to be able to take higher temps. When I was a Eurovan driver they were notorious for frail trans. They had synthetic ATF (Pentosin) from the factory and that was not good for anything much over 250. I exceeded that by a few degrees in the mountains in the summer and changed the fluid shortly thereafter to be safe.
