Old 06-15-2021, 09:35 PM   #1
RoadRacer4Life
Owner: DeathWagon
RoadRacer4Life's Avatar
Default Oil pressure how low is too low?
The oil pressure in the ole Champ wagon has never been stellar but I was curious what's considered too low.
Hot oil pressure is like 15psi at idle 800-900rpm
Hot oil pressure is around 40-45 psi at 5000rpm.
Time to build it?
Replace oil pump?
Already recently replaced oil feed tube seals so I doubt that's an issue..
-Sam
90 245GL 2JSWEDE 2JZ 245...
91 245GL Team Battle Wagon Chumpcar
93 245GL Street Beater
Old 06-15-2021, 10:22 PM   #2
Dan
Watching the World burn
Dan's Avatar
It's on the low side, but not dangerously low, motor is tired, not shot. what weight oil? I used to up the weight or add STP type additive to buy time
1985 Chevy TPI V8 740.
Old 06-16-2021, 09:58 AM   #3
kyote
Living The Dream
kyote's Avatar
I've always heard the 1psi per 100 rpm at hot idle was about the minimum before it would give up the ghost. You're getting pretty close to that. Time for Lucas?
Old 06-16-2021, 10:01 AM   #4
Beep beep zip tang
You should have slapped some new bearings in there when you did the oil feed seals.
Old 06-16-2021, 11:11 AM   #5
shoestring
shoestring's Avatar
Different kind of how many psi can a stock support
In our race car we ran 20w50 Castrol, later squirter block. Hot we had about 20psi, and at full chat it would just tickle 50. We do have fresh bearings in the bottom end, though, for what that's worth.
Old 06-16-2021, 12:06 PM   #6
rb92673
My rebuilt squirter with new bearings and oil pump seems to run 20 at idle and about 45-50 psi above 3k. VDO gauge/sender. 15W-40 diesel oil. It does drop on long left hander turns.
Old 06-16-2021, 12:07 PM   #7
cosbySweater
cosbySweater's Avatar
what oil cooler are you running?
1995 Porsche 993
2013 VW Passat TDI
Old 06-16-2021, 01:46 PM   #8
90volvo
On my recent rebuilt engine, its running 10 at hot idle and 50 at 3000 rpm. I believe has something to do with oil cooler. I did shorten my oil cooler lines and that helped. I was told running 10an lines are to big and if I switched to 8an oil pressure would increase. I think my engine is fine, I do run my idle up higer than most to keep oil pressure from dropping to low. I know rodders like low idle to hear the cam loping. But even in a ford you oil pressure drops big time.
B230ft rebuilt -MS-Turbo-E85
1985 240 Work in progress.
Old 06-16-2021, 02:30 PM   #9
The 240T cooler makes idle oil pressure pretty low, ~14 psi, on my car, FWIW.
Old 06-16-2021, 10:52 PM   #10
cosbySweater
Exactly why I ask
Old 06-17-2021, 12:16 AM   #11
spock345
spock345's Avatar
With redblocks I've just come to not worry so much about oil pressure so long as the light doesn't flicker at idle or drop below 1 bar (~14psi) on a hot idle. B18, B20, and B230 motors have already a wide variety of oil pressure values for me. Usually on the lower end when hot even with thicker oil (15w40 or 20w50) and a relatively fresh motor.
1967 122s, B20F, M40
Old 06-17-2021, 01:05 AM   #12
Marvelous3
Who engineered this?
Marvelous3's Avatar
Bmw makes 10w60 oil...
Old 06-17-2021, 09:53 AM   #13
rb92673
On mine I have an oil cooler and a remote oil filter. No idea who made the oil cooler.
Old 06-17-2021, 10:26 AM   #14
283SD
Main and rod bearing clearance, will be the key to oil pressure, and oil pump out put volume is another factor . Small oil lines to cooler/remote filter restrict oil flow. I run -10 lines on the V8 car with remote oil filter [1&1/2 quart] and 16 row oil cooler. My MG Midget 1275cc runs -10 lines, remote oil filter,13 row oil cooler, 70psi hot @ WOT [8,500 RPM] I,m going to up the pressure relief valve. Bearing clearance and oil pump out put and volume are the key to oil pressure. A good rule of thumb is 10 lbs per 1000 rpm The Midget runs 40 lbs at idle hot @ 1,100 RPM.
Old 06-17-2021, 10:30 AM   #15
Beep beep zip tang
OP, did you install piston squirter by any chance?
Old 06-17-2021, 11:30 AM   #16
gsellstr
gsellstr's Avatar
Noticed a drop in pressure when I swapped in the RX7 cooler. Needed new fittings, ran 1/2" push-lock hose from the stock hardlines to the RX7 banjo's. Factory squirter, hot idle with decent bearing clearances and an M181 pump, running 10w40 M1 is around 1.8-2b, hot cruise at around 2600 is around 2.8b, hot 4500rpm is around 3.2b.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 06-17-2021, 02:51 PM   #17
MikeSr.
What, me worry?
MikeSr.'s Avatar
My stock B21ft in the flathood runs low at hot idle, but the light never flickers- it has had bearings and pump done in the past.
I coulda had a V8!
Old 06-17-2021, 06:39 PM   #18
mck1117
We ran a full day of endurance racing with a paper towel jammed in the oil pump inlet, running 20-23psi at wide open, high RPM. Rod bearings looked great! 15 at idle is just fine.
mck1117 is offline   Reply With Quote
Old 06-18-2021, 12:51 AM   #19
bobxyz
bobxyz's Avatar
From my yellowing 1985 GLT Owner's Manual:
My original ~350K miles B21FT engine definitely flickered at idle when hot. My rebuilt B21FT doesn't flicker, but the hot idle pressure is certainly way on the left of the gauge. And yes, the pressure noticeably drops when the oil cooler thermostat opens.
Old 06-18-2021, 06:10 PM   #20
AnthonyHardy2
AnthonyHardy2's Avatar
I ran my NA B23 for about 8 months/10k miles with 15w40 oil with the oil pressure at about 8psi@idle/35psi@3-4k. The oil pressure light was on solid until about 1500 rpm and it ran fine until I pulled the engine so yours probably won't blow up or anything
AnthonyHardy2 is offline   Reply With Quote
Old 06-21-2021, 09:57 AM   #21
RoadRacer4Life
Owner: DeathWagon
Thanks for all the info fellas.. After more research I think I'm still in good shape.. This engine has never been out of the car so I was a bit worried but considering I run both the 740/940 oil/water cooler plus a large external oil cooler plus an external oil filter and I'm using the oil pressure switch to feed both the oil pressure gauge plus switch plus the turbo oil feed that my 25 year old VDO electric oil pressure gauge might be reading just a tad low.. Car still runs great.. I'll upload some video from this weekends PCA track day shortly.
-Sam
Old 06-21-2021, 11:07 AM   #22
mikep
The MP
mikep's Avatar
Excellent.
eww..
(not a fan of the loads of VI improvers in those wide spread oils, especially in a performance engine)
Old 06-21-2021, 05:36 PM   #23
gsellstr
gsellstr's Avatar
I did finally replace my old sender when it started getting twitchy, definitely picked up some oil pressure, or at least reported pressure once things got hot. The old sender didn't take to heat very well, so there was a broader spread in pressure between hot and cold, also a lack of pressure build with RPM when it got hot.
Old 06-21-2021, 05:44 PM   #24
Cwazywazy
Single jingle
Cwazywazy's Avatar
I used to get 1 bar with warm idle and close to half a bar with very hot idle (after beating on the car)
Since adding the air/oil cooler setup, I now see half a bar at warm/hot idle. I think oil pressure when driving also went down a bit, it's something like 2-2.5bar at 2000rpm.
I'm considering getting rid of the oil gauge, it's too stressful to look at in traffic.
I don't know what I have
Old 06-21-2021, 11:38 PM   #25
lummert
lummert's Avatar
10 psi per 1000 rpm is what I was always told.
