Old 03-17-2016, 02:49 PM   #176
760IT
Yeah I just got the exhaust housing off I see the snap ring now
760IT is offline   Reply With Quote
Old 04-13-2019, 04:45 PM   #177
smoothdurban
I do my own stunts
smoothdurban's Avatar
Do we know the size of the banjo bolts for the coolant supply and return on the 15G turbo?
On my 13 C they are 14 mm but it appears they are smaller like 12 mm on the 15G I bought.
Update I found a couple of adaptors that allow you to run a 12 mm banjo bolt through a 14 mm coolant line.
https://www.ebay.com/itm/SAAB-Turbo-....c100284.m3505
1983 242 Turbo w Tremec T5 154,000 km's B230FT LH2.4
2019 VW Golf R w 6 Speed w 2020 kms NEW DD
@smoothdurban on IG
Old 04-14-2019, 07:43 PM   #178
soclosenotnear
I was able to reuse all my 13c lines and hardware.
check my feedback here
Old 07-31-2019, 07:20 AM   #179
1slo9_4_oh
1slo9_4_oh's Avatar
this thread will likely never die lol. so as the photos are dead from the original post, i know a 15g conical flange fits but would a straight flange 16t reclocked, fit a stock downpipe?
1990 Volvo 740 Sedan Turbo 371k M46
-16t at 16lbs daily, 3"maf, 3"intercooler piping
-huge fmic, 390cc gm injectors and 2.5" straightpipe
-blitz bov and turbo timer, saab fuse harness (hids,fogs,a/c)
-ipd sways front/rear, lwr chassis and strut bar, billy hds
-hood bra, 850 roof rack, 740se spoiler, 760 front end swap
Feedback Thread:
http://forums.turbobricks.com/showth...88#post4905988
1slo9_4_oh is offline   Reply With Quote
Old 07-31-2019, 07:39 AM   #180
oldschoolvolvo
oldschoolvolvo's Avatar
If you put the conical TD04HL turbine housing on the 16T then it will bolt up to the stock downpipe. You will need to modify the downpipe flange to bolt to the flat flange turbine housing.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 02-08-2020, 11:22 AM   #181
bennyg
So I have a new TD04H-13c ? stainless downpipe , and I'm going to do the 15G or 16T turbo upgrade , from the research I have read there are 3 hotside options as far as purchase of hotside pieces , 1.] the conical style from early 850's ,which would make my swap easy and match my existing Stainless D.pipe,but is less efficient 2.] the flat/straight flange which was on later 850's / which is more efficient ? or 3.] the flat /angled hotside housing which is from the V70 ? which is a true? 3" or as close to ,and the most efficient ? This leads to my dillema , since the early conical hotside housings are less efficient ,and harder to find for the 15G upgrade setup ,I should bite the bullet and modify my new Classic Swede pretty pipe to accomodate a flat flange .Dillema # 2, will either the FLAT/straight ,and the FLAT/angled flanged hotside housing replacements work on my 1991 B230FT 745 ? and does anyone know of a company selling a pre existing transition pieces or should I just plan on fabricating a flat flange W/ a short 3" stubby and transition weld/clamp to my pretty pipe ? AND/OR last but not least does anyone have any of the pieces /or suggestions they want to SELL for my 15G /16T swap like housings ,turbo, etc etc Thanxz to all sincerely Ben
bennyg is offline   Reply With Quote
