89_740Turbo
- Apr 10, 2018
- Central New Jersey
I recently got my hands on a super low milage ft motor and decided to go full motor swap. New seals, tranny and all. I'm running a 16T right now with a Yoshifab wastegate. The car purrs and wants to rip! Only problem is I'm on lh2.2
I am using Sbabbs chipped lh22 chip and hoping I can remove this boost cutoff on my car. Its cutting off at 15lbs and is like to run 18lbs.
I've researched the cutoff issue and have read nearly all the close to 2 decade old threads, which mostly have conflicting information. Some say there is something under the peddles, others say a hose near the ECU. Confusing. I'm running Jetronic ECU. Any help is appreciated
