Old 04-16-2021, 08:05 PM   #1
240-FAN
Default Fitting Virgos on a 940
Is there any possibility to put the Virgos off my 240 on my 940SE without going to extraordinary lengths?
I had them refinished and powder coated and would hate to get rid of them...
240-FAN is offline   Reply With Quote
Old 04-16-2021, 08:36 PM   #2
You don't say what year your car is but virgos didn't fit on my friends 93 940 wagon. Those large front calipers rubbed on the wheels.
Old 04-16-2021, 08:42 PM   #3
redblockpowered
cone dodging dilettante
redblockpowered's Avatar
Yeah doesn't clear in the front.
I sell chips for LH 2.4!
Old 04-17-2021, 05:16 PM   #4
240-FAN
Oversight on my part, it’s a 1991 940SE.
What are the other options/rims that are 15” and would fit the car?
Old 04-18-2021, 06:37 AM   #5
Otto Mattik
board member
Otto Mattik's Avatar
I'm wondering if the 940 wheels are dished in such a way as to provide more room for the calipers, since according to this info, the offset is within the same range as a 240 ?
https://www.wheel-size.com/size/volvo/940/1991/
Old 04-18-2021, 12:51 PM   #6
daijoubanai
waste of skin and blood
daijoubanai's Avatar
If I had to guess, I'd say the inside diameter of the virgo is smaller compared to the 15s on 7/9 cars. Most 240s came with 14s, so I'm sure when they designed the virgo clearance issues with a 15 wasn't a concern. I've never had virgo wheels, so that's just a guess looking at pictures online.
daijoubanai is offline   Reply With Quote
Old 04-18-2021, 03:49 PM   #7
Fa182
Stage 1
Fa182's Avatar
Aren't Dracos 15" too?
Old 04-18-2021, 03:55 PM   #8
Janspeed
yes, they are but the profile of the casting is probably a bit different, different enough to fit over the 940 brakes.
If the OP really wants to use the Virgo wheels maybe he can downsize the front brakes to those from a 740/780? Those brakes are a little bit smaller and consequently the calipers are a matched to those smaller rotors.
Old 04-18-2021, 06:15 PM   #9
Fa182
Stage 1
Fa182's Avatar
Right, I just wasn't sure if they were 15", I know they fit 7/9 and since OP seems to be looking for 15" only...
Stock steelies are 15" too.
Old 04-19-2021, 08:04 AM   #10
240-FAN
Thanks everyone. The car came with the 15” rims that I believe were offered on the 960s.
Seems like a weekend project to measure the ID of both rims to see what the difference is.
Old 04-19-2021, 08:42 PM   #11
lummert
lummert's Avatar
I think it depends on the 91 940SE front brake setup. Does it have 287mm rotor with dual piston caliper? Or 280mm rotor with single piston caliper?
So I looked it up. Shows that 15" Virgo only fits 240 and 260.
Old 04-19-2021, 08:44 PM   #12
lummert
lummert's Avatar
20 slot wheel? if so, it was used on 88-90 760 and 92-94 960.
Wheel on my 88 765 is Omega, Volvo 1359180. It fit the original 287mm rotors and Bendix dual piston calipers as well as the Jumbo 280mm rotors and Girling single piston calipers.
http://www.autorimshop.com/wheel/vol...wheel-rim.html
Old 04-19-2021, 09:36 PM   #13
240-FAN
Thanks for checking. I had taken for granted that they were all 287mm rotors across all MYs of the 940s.
I just did a quick check on RA under the 1991 940 2.3 turbocharged - all the front rotor options are showing 280mm. Does that mean the Virgos *might* fit? RA shows the 240s have a 263mm front rotor.
Did the later MY 940s switch to the 287mm rotors?
Old 04-19-2021, 09:38 PM   #14
240-FAN
These are the stock wheels the car came with
https://images.app.goo.gl/cvYivaNpoazPb8657
Old 04-20-2021, 03:39 AM   #15
Otto Mattik
board member
yeah but those Dracos tho
Old 04-20-2021, 04:55 PM   #16
Fa182
Stage 1
Fa182's Avatar
I know right!
Not sure what you mean, I was just saying that the stock steel wheels on a 940 are 15".
