Old 02-14-2021, 06:27 AM   #26
mhgreen
mhgreen's Avatar
I've been catching up with family... arrived in Indiana this past evening, 2300 miles from Portland. Thermostat issue was the only kink. Having a new one on hand was convenient. After the quick swap at the hotel in Cheyenne everything was smooth sailing. The car didn't like to start in -0* temps but I encountered no issues otherwise. No stalls, no emergencies, no
no-starts. What a solid ride!
mhgreen is offline   Reply With Quote
Old 02-14-2021, 10:12 AM   #27
84B23F
84B23F's Avatar
My 89 240 with cold start injector, fires right up...complete tune up...OEM injectors cleaned and flow tested...new intake gasket...new temp sensor...new FPR..new O2. No complaints.
Old 02-14-2021, 03:12 PM   #28
84B23F
84B23F's Avatar
Footnote - I turn ignition key to on position and let fuel rail come up to pressure, and then turn to start position within several seconds...about when fuel pump is done priming.
