Old 09-18-2022, 04:24 PM   #1
VolvoLatAm
Default Cleaning up front side indicator lenses and tail lights
What material are the Bosch and Hella 240 tail lights made from originally?
What material are plastic turn signals made from?
--are they polycarbonates or acrylics or something else?
https://www.eplastics.com/blog/chemi...lic-plexiglass
Besides soap and water, I plan to remove exterior lens superficial scratches and already have read that diluted ip alcohol can crack, distort, and cloud plastic tail lights even in small amounts.
Any exterior plastic polish recommendations?
VolvoLatAm is offline   Reply With Quote
Old 09-18-2022, 04:31 PM   #2
hessam69
Nothing beats buying new lights. Age and sun damage can possibly be unfixable
Old 09-18-2022, 04:35 PM   #3
VolvoLatAm
you surely can buy new lights and have superficial scratches
Old 09-18-2022, 04:59 PM   #4
hessam69
True, but I believe in your case the aging, cracked, faded, brittle plastic would be a much more noticeable eyesore than light almost invisible scratches on new units, if there are even any new lamps with scratches
It's up to you and how much you wish to spend I guess
Old 09-18-2022, 05:13 PM   #5
VolvoLatAm
https://imgur.com/a/4R5JApF
Old 09-18-2022, 05:19 PM   #6
142 guy
142 guy's Avatar
Some buffing compound will remove the scratches and surface haze. Some Meguiar's 105 and a DA buffer will work wonders. If you need even more shine finish up with M 205. If the surface is really far gone you can start off with some 400 or 600 wet grit.
Old 09-18-2022, 05:42 PM   #7
VolvoLatAm
anybody ever try this out: https://www.amazon.com/Novus-7100-Pl...ustomerReviews
Old 09-18-2022, 06:26 PM   #8
TestPoint
TestPoint's Avatar
I have used 1500 and 2000 grit w/d paper on plastic with good success. Followed up with a plastic polish as you link to. Looks like new.
Ford V8 Conversion Manual -
Old 09-18-2022, 06:26 PM   #9
Fa182
Stage 1
Fa182's Avatar
Maybe this helps
