Old 07-06-2021, 12:12 PM   #1
Wilford Brimley
Is posting from the grave
Wilford Brimley's Avatar
Default I know its not rwd but I need help xc90
So my 04 t5 xc90 has this odd thing where its really smooth up to 50,55 ish and up where it seems to tremor under acceleration, it's good up till that speed and i don't even know where to start with it
Deb the 944T Tina XC90 T5
Old 07-06-2021, 01:39 PM   #2
HiSPL
Fanking Champion 1993
HiSPL's Avatar
It'll most likely be either the CV axle or the Tie Rod ends.
If it only happens on power I'd look at the axles. If it randomly does it on or off power, tie rod ends.
Could also be ball joints, bad shock, bad tire, or even subframe bushings, but I'd start with the CV axle.
Beets taste like buttfeet.
Originally Posted by 240 240 View Post
water-cooled VW owners can't even tell you the flavor of Cheetos they ate last night.
Originally Posted by Lando
Tinnitus and hearing loss? Sounds like your ears could tolerate some Bose 901s!
96 960 (rotted)
88 244
06 XC90 V8
03 V70(crashed)
92 745 Turbo
Old 07-06-2021, 02:15 PM   #3
Wilford Brimley
Only under power
Old 07-06-2021, 07:03 PM   #4
Jeh
Smorgasbord of Excellence
Jeh's Avatar
Most likely its the axles.
Originally Posted by RedFridge
That's why I love this place. Truly an information warehouse.
Originally Posted by kyle242gt
I post not for information, but for ignorant entertainment.
Brakes help you avoid crashes.
Breaks are what you get when you crash.
1994 Jaguar XJ6
Jeh is offline   Reply With Quote
Old 07-06-2021, 07:46 PM   #5
Wilford Brimley
I'll check thanks guys
Old 07-06-2021, 07:52 PM   #6
GTJordan
Been here for too long
GTJordan's Avatar
If everything is tight in the suspension (tie rods and ball joints- use a pry bar and pry down on the control arm between arm and spindle to check for play), then likely axles. I've also had a rumble under acceleration from the front CV joint on the prop shaft assuming it is AWD.
80 242- 2.5L 16V, NIW intake/exhaust, GT3076, MAxxECU Race, KL Stg 2 cams. T5 w/ 2.95 gearset. Porsche brakes, Gaz short coilovers/shocks and Kaplenkhe suspension, Trutrack.
Old 07-06-2021, 07:56 PM   #7
Wilford Brimley
It is awd
Old 07-06-2021, 09:34 PM   #8
Wilford Brimley
https://youtu.be/E3MeGFeyhgo a link to what might be a bad tie rod? It moves pretty easily
Old 07-07-2021, 11:45 AM   #9
Wilford Brimley
I dont mean to pry but I'm supposed to take my kids camping over the mountains in a few days and hope to figure this out thnx again guys
Old 07-07-2021, 01:39 PM   #10
GTJordan
GTJordan's Avatar
No the rotation is normal. You need to lift the front wheel off the ground. Support the car but let the suspension dangle.
Grab the wheel side to side and now shake quickly. Does it knock back and forth? If so, get someone to shake it and look at the tie rod, put your hand on tie rod, is it moving around where it enters the spindle? Bad tie rod.
While up in the air, check the ball joint with the description I listed above.
Jordan
Old 07-07-2021, 03:10 PM   #11
Wilford Brimley
Thanks dude.
Old 09-12-2022, 03:34 PM   #12
Wilford Brimley
So I changed the tie rods and motor/tranny mounts and if you push the gas pedal at like 60mph the damn thing shimmys like it's got death wobble from hell still
Old 09-12-2022, 05:19 PM   #13
GTJordan
GTJordan's Avatar
Anything when decelerating?
Only does it under load?
I'm going to assume everything suspension is tight, control arm bushings are in good shape, upper spring seats aren't torn. That sort of thing.
Could it be a transmission slipping/shuddering issue?
Axle or prop shaft is where I'd go. If I were diagnosing this at work (it would be easier for me) but I'd probably pop the prop shaft out and look at the front CV joint of it. Is it bound up? Drive it with the prop shaft out. If the vibration is gone, it is prop shaft or rear. If it is still there, it is something in the front.
Things I have seen that cause vibration under load at highway speed.
Missfires - typically have a pending code set but I have seen no flashing CEL/codes on some.
transmission slipping (this is uncommon for me to see in the flat land, but I've seen a few on cars that come from the mountains)
Prop shaft front CV joint seized. This usually causes a vibration that gets worse as speed increases. I have had more than a few that were only under a load though
Front axles. I haven't had to change many on XC90 and P2 chassis honestly. Unless the boot has been torn open for the last 6 years.
Rear axles usually cause a "pop" noise when turning under load. Only had one or two. Never a vibration under load.
AOC unit- usually vibrates if the tires are the wrong size, worn an excessive amount, different brands front to rear etc.
Old 09-12-2022, 05:21 PM   #14
Old and boxy but good.
Must have some bad suspension bushings? How did the axles check out? Wheel bearings all felt good? If it's still only under power and the axles are fine. Then I'd look closely at the suspension.
Old 09-13-2022, 02:05 PM   #15
nel621
Try something simple first. Have your tires Road Force Balanced.
Old 09-13-2022, 02:13 PM   #16
HiSPL
HiSPL's Avatar
I still say its the CV axle.
Old 09-13-2022, 06:22 PM   #17
GTJordan
GTJordan's Avatar
A vibration under load, is almost guaranteed to not be a road force issue. A good road force balance is not cheap either, specially if you have to start swapping tires on rims. I start at 2.0 hrs for a road force balance.
Jordan
Old 09-15-2022, 10:00 AM   #18
Wilford Brimley
There is a super loud pop coming from what sounds like the front when turning and reversing, or extreme braking. The shutter is ONLY under power it's weird
Old 09-15-2022, 10:34 AM   #19
Jack leg
Never A Break
Jack leg's Avatar
I had almost the exact same issue in my 06 Honda Odyssey. Ended up being one or both of the CV axles. Both axles seemed fine when I pulled then but after I test drove it with the new axles the van was back to normal.
1994 940 Turbo Wagon (400k mile Body, new engine, T5 trans)
2000 Ford Excursion V10 4x4 (Denim Blue Interior)
Jack leg is offline   Reply With Quote
Old 09-15-2022, 10:45 AM   #20
Wilford Brimley
Ok I'll look into that and the other suggestions thanks a ton guys
Old 09-15-2022, 12:30 PM   #21
Wilford Brimley
Also is it OK to disconnect the shaft and drive to see if that's the issue
Old 09-15-2022, 08:21 PM   #22
GTJordan
GTJordan's Avatar
Which shaft?
The prop shaft has to be taken out of the pinions on both ends. You can't leave one in. I remove it completely when I'm at work.
You can't remove a front axle and drive it.
The popping while turning makes it sound even more like a bad front axle (or your bevel gear has completely failed, but you'd be hearing alllllll sorts of other terrible noises)
Jordan
Old 09-15-2022, 11:04 PM   #23
Wilford Brimley
Which shaft?
Jordan
I was referring to the rear axle, my mistake...also there aren't a ton of bad nosies at all just the aforementioned pop. I watched a video of removal...doesn't look bad except where the (haldex?) Side gets kinda stuck
Old 09-15-2022, 11:11 PM   #24
I guess bad front axles.
Old 09-16-2022, 05:48 PM   #25
GTJordan
GTJordan's Avatar
I have a punch that I've bent at about a 45 degree angle that can be inserted in the unthreaded hole, then the punch hit with a hammer to pop it out. Some can be a real pain. The front one will either fall out, or it is going to suck since there isn't as much room as the rear.
Jordan
