Old 08-20-2022, 11:24 PM   #1
stev
stev's Avatar
Default Exhaust Manifold Crack
My exhaust manifold had a crack in it so I mig welded it to fill it. Now driving the car for a couple months I get an exhaust leak in the same spot as that crack, so today I took the manifold off to see a new crack right above where I welded the old crack. It's an RSI turbo exhaust manifold for a B230F+T so I'd like to know how the crack should be fixed instead of just filling the crack again and calling it a day.
stev is offline   Reply With Quote
Old 08-20-2022, 11:29 PM   #2
white855T
What material is the header made out of? Ss? Once you know, you can find someone to do a proper repair.
Old 08-21-2022, 02:57 PM   #3
Radtap
Radtap's Avatar
When you first fixed it did you drill holes at the ends of the crack? If you did not it will just continue cracking
Feedback
Radtap is offline   Reply With Quote
Old 08-21-2022, 05:32 PM   #4
stev
stev's Avatar
nope, good to know.
Old 08-21-2022, 07:04 PM   #5
Old and boxy but good.
^^This plus carefully V groove the crack with a die grinder or dremel so the V can
be filled with good penetration weld.
Old 09-04-2022, 11:38 PM   #6
stev
stev's Avatar
Finally getting around to fixing the cracks in my exhaust manifold but today I found the cracks travel further than I initially thought and eventually become so small I loose sight of them. One of the cracks split off into 2 cracks and they both travel further until they fade away. I used some UV dye to help see the cracks and they appear to go further on the inside then on the outside. So do I just drill a hole where they appear to end, I don't want to drill a hole where a crack hasn't finished cracking through the whole piece of metal and it continues to crack after patching it and ending it. What about cutting that section of tubing out and welding in a new tube?
Old 09-05-2022, 12:39 AM   #7
Radtap
Radtap's Avatar
Crack should be drilled completely through. Where is the crack exactly? In your first post you said another crack appeared above where you originally fixed one crack. New cracks are forming from either a weld weakening the surrounding metal or more likely stress cracks from a big ol' turbo hanging off the thing. Might wanna add a brace to take some weight off the manifold itself, either something bolting to the exhaust stud or using the valve cover studs.
Old 09-05-2022, 01:00 AM   #8
stev
stev's Avatar
I think the crack just split into two from the original one and ran above the old one. I'll get some pictures of it. It's close to the flange so it can be a stress thing. When you mean completely drilled through, does that mean drill holes on each end of the crack or cut along the whole crack?
Old 09-05-2022, 01:29 AM   #9
stev
stev's Avatar
So here's some pics and where the lines are, I spent most of the time grinding down the old mig weld but there is some still there I didn't grind off on the bottom.
I drilled two holes there because the cracks were joining and splitting off from there. But the crack on the left runs along the weld I didn't grind off, I don't remember if the old crack was under that or that's just the original crack. But after the whole on the right it splits off again and connects back in the next picture.
The orange line is the crack that I welded over the first time a while ago but still exists, just can't see it from the outside. The green arrow is where they both connect from earlier. Then that line goes on until it fades away. That crack is new.
And then there the two lines from the inside, the orange one is the one you can't see from the outside.
Old 09-05-2022, 02:39 AM   #10
Radtap
Radtap's Avatar
Looks like your original weld didn't penetrate, grind a groove in the crack and turn that welder up so it can penetrate the metal. Get that metal as clean as hospital operating table too.
https://www.youtube.com/watch?v=MIHKZBf7rwA
He works tig but still good info
Old 09-05-2022, 04:05 AM   #11
stev
stev's Avatar
Alright thanks man I'll prepare for tomorrow.
Old 09-05-2022, 07:23 AM   #12
white855T
That header will keep cracking unfortunately. Seen that a bunch of times.
Old 09-05-2022, 11:35 AM   #13
Radtap
Radtap's Avatar
All I’m saying is in Google when I looked up the header the first auto fill result was “rsi exhaust manifold crack”
