Old 08-23-2022, 11:13 PM   #1
1968 volvo
Default 240 exhaust gasket change.
I'm going to change out the exhaust gasket(s) on my dads 93 244. It appears to be rather easy. I figure nows a good time to ask if there are usually and unexpected surprises when doing this job? I've done a few exhaust gaskets before and I imagine it is about the same. I've already started soaking the bolts in wd40.
volvvovlovlvovovlovlvovlvovlvovlvovlvooovlovovovoo vl
1968 volvo is offline   Reply With Quote
Old 08-24-2022, 10:32 AM   #2
oldschoolvolvo
oldschoolvolvo's Avatar
I assume there is a leaking gasket?
There is obviously the potential for a broken stud. I'd use PB B'laster instead of WD40.
Otherwise, yes it is simple...separate manifold from head, replace gaskets, re-tighten manifold.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 08-24-2022, 11:28 AM   #3
1968 volvo
cool this is what i assumed. i would be using blaster if i had it on hand but i figured wd was better than nothing. yes one of the gaskets is leaking. it sounds like a tractor any time you get on the gas. someone even asked me if it was diesel.
Old 08-24-2022, 11:29 AM   #4
JohnMc
JohnMc's Avatar
Just pay attention to the orientation of the gaskets. They're not symmetrical.
And hope you don't break any studs. California is a good sign for that.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 08-24-2022, 12:37 PM   #5
2manyturbos
There is no comparison. WD-40 is almost useless as a penetrating oil. Don't attempt this job without using PB Blaster or some other known, good penetrating oil. One broken stud and you will turn a 2 hour job into an all day job.
Old 08-24-2022, 12:42 PM   #6
Mr. V
Mr. V's Avatar
Put some anti-seize on the bolt threads going into the head; this makes future removal easier.
Clean the manifold and head surfaces well before putting new gaskets on.
Torque to spec, and retorqe after a few hot /cold cycles.
Old 08-24-2022, 12:42 PM   #7
1968 volvo
i was planning on getting some so thats good.
Old 08-24-2022, 12:43 PM   #8
JohnMc
JohnMc's Avatar
I'm not entirely sure if it's a great idea or not, but sometimes on stuff that I'm pretty sure wants to break, I'll tighten it slightly to break it loose, before switching to loosening it.
Old 08-24-2022, 02:00 PM   #9
1968 volvo
I have done this before with great success. My Grandpa says thats an old farmers trick and he has used that all his life. He claims a lot of stuff as old farmers tricks and it sounds like to me that they were the smartest people to ever walk the face of the earth.
Old 08-24-2022, 02:02 PM   #10
1968 volvo
do you happen to know know what spec is? I imagine around 25 ftlbs
Old 08-24-2022, 02:33 PM   #11
Khrrck
Professional Amateur
Any tips on cleaning the surfaces? Going to be doing the same job myself relatively soon - old gaskets look pretty done around the edges but not sure how bad the mating surfaces will be. Also have the downpipe gasket which will likely be even more of a pain.
'87 240 budget wagon. Sadly departed.
'88 240 eggshell wagon.
Old 08-24-2022, 03:36 PM   #12
2manyturbos
14-17 lb*ft. At 25 you will snap them off.
Old 08-24-2022, 03:37 PM   #13
Old and boxy but good.
Probably something more like 16-18ft lb. As suggested make sure you go back and snugg
them up after some heating cooling cycles. You should always replace the locking nuts
with new ones. They are the crimped type locking nuts made for high heat.
I usually clean surfaces like that with very fine grit cloth or sandpaper like 600 grit.
1982 242 turbo. 338k miles. MVP/ BNE coilovers and 3" exhaust. Flowed 405 with a V15T. Cossie turbine housing with upgraded compressor housing. With wildly uncontrolled wastegate. 90+, IPD remote oil filter. Some other goodness, too. Restored in 2k. Now ready for a 2nd restoration.
Old 08-24-2022, 04:18 PM   #14
Mr. V
Mr. V's Avatar
There shouldn't be a lot of crud such as broken gasket material or god help us old permatex but if so soak it in gasket remover fluid then scrape off.
Clean surfaces well with either carb cleaner or brake cleaner.
YMMV, but after cleaning I get out my drill, put on the attachment that bends the angle of attack ninety degrees, put on a wire brush and dress the surfaces with the brush.
Finish off with fine grid sand paper, "just because."
Old 08-24-2022, 06:00 PM   #15
lookforjoe
Making Volvo Parts Fit
lookforjoe's Avatar
If you can remove all the studs, use a roloc fine grit or similar, easier with air tools, but OK on a drill, just slower. Get the flanged locknuts, and don't discard the original flat washers, they hold up much better than any generic version
these were my gaskets, and it wasn't even leaking - they just fell apart upon removal
My XR July2013 - 446AWHP @ 8K rpm C30 AWD conversion 740 pickup thread Feedback Thread
Old 08-24-2022, 09:34 PM   #16
OVERDRIVE
OVERDRIVE's Avatar
The car is a 93 and you're in California so it may be an EGR manifold too. Loosening the pipe is pretty simple in theory. Mine came right apart when I first took the manifold of, but your mileage may vary.
1990 244 DL AW70 189 white.
OVERDRIVE is offline   Reply With Quote
Old 08-25-2022, 06:38 AM   #17
dalek
Benchracer Tribe
dalek's Avatar
Talking about cleaning, running a brush through the threads before reinstalling will make you happier later.
Feedback!
Old 08-25-2022, 06:57 AM   #18
Otto Mattik
board member
Otto Mattik's Avatar
When my grandpa first went in the Army, they asked him:
Q "What did you do in civilian life ?"
A "I was a farmer"
Q "If the tractor broke down, did you fix it yourself ?'
A "No, we just waited around for a mechanic to show up."(sarcasm)
Army personnel officer: "Ok, you're going to be a mechanic."
(he was sent an aircraft mechanic school)
Old 08-25-2022, 03:47 PM   #19
1968 volvo
A "I was a farmer"
ha! My grandpa is the kind of person who paints his case orange tractors primer grey because the orange is too flashy and looks too nice and will get too dirty too fast.
https://www.google.com/search?q=case...tP6Z_YFXhywqeM
hes got one like this but primer gray.
Old 08-25-2022, 04:46 PM   #20
swedishiron.com
I sell Volvo parts!
Quite true.
I did this same repair on a '93 245 last year with more than 330,000 miles on it. It still had the original exhaust gaskets at both locations.
Not only did I snap off one of the header studs (where the manifold meets the "downpipe"), but I also snapped off an exhaust stud in the head.
Both happened after repeated, generous dousings of PB'laster over the course of several days.
It really made me wish I had one of these tools:
https://www.amazon.com/Buster-Power-...dp/B074438D7D/
If it feels like the nut is not budging, STOP. If you don't, it's just more suffering.
Here's my feedback thread:
http://forums.turbobricks.com/showthread.php?t=25568
I ship small packages/purchases on Fridays, and larger ticket items via FedEx in the middle of the week.
swedishiron.com is offline   Reply With Quote
Old 08-25-2022, 06:28 PM   #21
283SD
Default Roloc sander
Originally Posted by lookforjoe View Post
if you can remove all the studs, use a roloc fine grit or similar, easier with air tools, but ok on a drill, just slower. Get the flanged locknuts, and don't discard the original flat washers, they hold up much better than any generic version
do not!!! Use a rolc sander unless yuo want to f'up the surface.
Old 08-25-2022, 08:51 PM   #22
lookforjoe
lookforjoe's Avatar
You have to know which grit disc to use. As stated, I use the fine disc. It does not eat the aluminum. You just have to pay attention to what you are doing.
Old 08-25-2022, 09:06 PM   #23
1968 volvo
You guys are scaring me lol
Old 08-25-2022, 09:21 PM   #24
lookforjoe
lookforjoe's Avatar
You can also go over it with a block sander, also works as long as the studs are removed. Works well for the exhaust manifold also. I used 240 grit on this header, they didn't finish it well from the manufacturer.
Old 08-31-2022, 04:34 PM   #25
1968 volvo
Ok. I’ve been really busy but also on my free time I’ve been trying to get a broken stud off the head. I have very limited tools at my disposal but if anyone have any more suggestions I’m all ears. The stud has been broken for a while as I found it that way. I tried double nutting it several times with no success. The nuts slipped both times and then on the third time I stripped the threads on the stud. I also tried whacking it with a hammer to break it free. It’s been soaking in pb for the past couple of days and not any help. I also tried vice grips on the already messed up threads. I stripped the teeth on my vice grips and it still didn’t go. I literally used channel locks to lock the vice grips in place. I’m out of things I know how to do with my tools. If anyone knows more tricks I would be willing to listen. My current plan is to re tap the threads on the stud and then double nut with red thread locker on the stud to see if that even does anything. My tool, arms, and mind have taken quite a beating. What’s next?
