Old 09-06-2022, 07:45 PM   #1
sbabbs
sbabbs's Avatar
Default 90 plus turbo headgasket replacement trick to know!
Take out this one stud then you can take off head and put back without touching turbo or manifold, it just stays in place there. Granted if you do not take out this one stud you can but you tweak the manifold holding bracket and scratch the bottom of the head on the alignment dowls...
See how tight the hole around that one stud is compared to all the rest? That is the alignment stud hole! Follow me for more pro tips....
Lightning
Ohh also my efn email is done.. I got outlook email simonbabbs at outlook.cum
1990 745 B230FT Getrag JohnV flywheel 240mm clutch 13c A-cam 3.54 G80 555K
1995 940 White racing wagoon. 13c.
Old 09-06-2022, 08:33 PM   #2
whatshouldido
very nice !
---1991 volvo 745 turbo wagon
**m47 swap incoming !
--1977 244 360k+ miles all original
** drive till wheels fall off
whatshouldido is offline   Reply With Quote
