Old 09-12-2022, 09:49 PM   #1
wht_245wagoon
Default Help
Not sure if this should be in this section. As the title suggests, I need help. I have been working on my 1990 240 for the past 2 years and have yet to have it up and running long enough to get it smogged. The starter was the last thing I just replaced and it was a monumental task as the PO used the wrong bolts and Loc-Tite. I have finally put it back together and now it doesn't want to start. It just sounds like it's cranking over and over. The battery is fully charged and both fuel pumps turn on when the key is on. I am in Socal in north county and was wondering if there is anyone local that could help. I have checked the forums and am a much better of a visual learner. I just wanna drive this sucker and enjoy it. Any help is greatly appreciated.
wht_245wagoon is offline   Reply With Quote
Old 09-12-2022, 10:12 PM   #2
James M
Bored member
James M's Avatar
Not necessarily the right section but I guess it is technically wanted. Maintaince and non performance is probably a better choice. If I was local I'd come help.
There are some good no start threads here that go over most of the options, work methodically to find out what doesn't work. Probably also worth doable checking you didn't unplug anything and forget about it
Old 09-12-2022, 10:22 PM   #3
- Stock PSI Or Bust -
I'd swap the fuel pump relay and go from there if it cranks over.
how psi stock cna sprout?
Old 09-12-2022, 10:33 PM   #4
philski o'flood
philski o'flood's Avatar
2 years!?!
Cranks but no start... fuel pump relay, crank position sensor, What ECU is in it... um it's got gas and a good fuel pump right?
Did you ever have it running?
philski o'flood is offline   Reply With Quote
Old 09-12-2022, 10:37 PM   #5
Click on my signature for the basic no-start diag for the DIY tech. You will need a $10 incandescent test lamp and a $10 for two cans of brake cleaner.
Has the flex plate been removed and re-installed recently?
Old 09-12-2022, 11:11 PM   #6
wht_245wagoon
I have had the car running, before. I drove it down from its initial place to where it is now. It was running fine then the starter made a really bad grinding sound so I had to replace it. It has probably 10 gallons of 93, fuel pumps both turn on and work. I'm going to go over and check all the connections to see if I am missing something.
Old 09-12-2022, 11:14 PM   #7
Take the oil filler cap off and confirm the cam is turning.
Read my no start thread. ---Confirm spark, clear flood, use brake cleaner.
Old 09-12-2022, 11:18 PM   #8
wht_245wagoon
I will try this 2mrw when I get off work and can hopefully get a second set of hands.
Old 09-12-2022, 11:22 PM   #9
240 has a starter jumper wire at the center of the firewall. Make a jumper wire, shove a stripped end in there if you gotta, and slap the other end to positive.
It's a blue/yellow wire with a female spade terminal. No helper needed!
Old 09-15-2022, 01:03 PM   #10
nel621
check that 25 amp fuse by the battery
Old 09-15-2022, 02:01 PM   #11
wht_245wagoon
Thanks, I am going through the no start diagnosis right now. I have spark at the coil will be testing to see if the fuel injectors are working as I pulled them from a JY car. If they don't I will put in my stock ones and send the others in for cleaning. I don't know if it would cause an issue but my car had the cold start injector but I switched out the intake to remove it. I plugged it back in so we will see. The cold start is a huge pain in the ass to do anything fuel related as it just gets in the way.
Old 09-15-2022, 04:09 PM   #12
Old and boxy but good.
Very common for fuel injectors that sit in the salvage yard for awhile to varnish stuck and or not spray properly.
Old 09-15-2022, 04:11 PM   #13
Does it run on brake cleaner?
Old 09-15-2022, 04:47 PM   #14
wht_245wagoon
I will do that first then swap injectors if needed. I should have a full can in the garage.
Old 09-15-2022, 05:39 PM   #15
Khrrck
Professional Amateur
Just be careful with the fumes if you are running it on brake cleaner or similar. Hot (>500C) brake cleaner can decompose into phosgene, a WWI war gas.
'87 240 budget wagon. Sadly departed.
'88 240 eggshell wagon.
Old 09-15-2022, 05:57 PM   #16
wht_245wagoon
Yea, just a couple of sprays to see if there is a fuel problem. I have a feeling that might be the issue.
Old 09-15-2022, 08:45 PM   #17
wht_245wagoon
Quick update, I sprayed brake cleaner and had my daughter crank. Still same sound and no start. Then I paid more attention to the belts and noticed that everything was moving except for the camshaft belt and found what looks like a chewed up washer behind the tensioner. Any idea what that could be. When I try and manually crank the engine the cam belt doesn't rotate.
Old 09-15-2022, 10:31 PM   #18
philski o'flood
timing belt
Old 09-16-2022, 01:12 AM   #19
wht_245wagoon
So looks like the camshaft dowel broke off and destroyed the washer behind the cam gear. I took the camshaft off and there is scoring on the #2 cap. The other caps are fine and smooth to the touch. I will try and add some photos.
Old 09-16-2022, 01:39 AM   #20
wht_245wagoon
Old 09-16-2022, 09:09 AM   #21
I don't really recall there being a washer that goes behind the cam gear in B230F. It's been a while since I've done one.
I can't tell right now from the pics, but that scored bearing surface isn't good. I've seen worse. It may not be the issue. It's a good idea to plastiguage the cam bearing surfaces when you install a cam. I'd also make sure all the oil passages aren't clogged.
Did you measure the valve clearances? I take out the hushers, set the clearances, then install new hushers.
Old 09-16-2022, 09:45 AM   #22
wht_245wagoon
The washer fits some B230s according to IPD's website. I have new stuff on order then I will be able to check the valve clearance.
Old 09-16-2022, 10:21 AM   #23
Before you put it all together, I'd spin the aux gear with a power tool and pump oil up to the head and make sure all the bearing surfaces are being fed adequate oil.
If I had to guess what happened here, I'd say the cam gear bolt wasn't torqued well enough when you put it all together.
Old 09-16-2022, 11:06 AM   #24
wht_245wagoon
Sounds good, I can do that when I get home with my impact to check the oil passages.
Old 09-16-2022, 11:34 AM   #25
white855T
Some earlier cars had the washer. My 89 740 has one. I remember b23 and b21 engines having them as well.
